Nikon Coolscan 8000 / 9000 ED
7 replies to this topic
#1 Tim Shim
Tim Shim
  • 50 posts
Posted 19 May 2006 - 10:19 AM
I was just wondering if anyone has tried scanning a roll of 16mm/35mm 'motion picture' film with Nikon's Coolscan 8000 / 9000 which is capable of accepting 16mm/35mm film strips.
I would think there'd be problems with registration but I don't know for sure as I've never used the Coolscan.
Has anyone tried this?
#2 Filip Plesha
Filip Plesha
  • 1267 posts
  • Croatia
Posted 19 May 2006 - 12:49 PM
Well you'd pretty much get killer scans, even from reversal and prints, but the registration would probably be bad.
#3 Matt Pacini
Matt Pacini
  • 1246 posts
Posted 19 May 2006 - 03:54 PM
Forget about it.
I entertained this idea a long time ago, but when I did a rough calculation of how much time it would take, it would be literally months and months of round the clock scanning to scan even a short film.
Add to that the time you'd have to tweak every strip of film you scanned for registration, and it would be like 3 years before you could start editing, and this is if you didn't have to work, eat and sleep!!!
MP
#4 Tim Shim
Tim Shim
  • 50 posts
Posted 19 May 2006 - 11:19 PM
Forget about it.
MP
Matt, I did some calculations and although yes, it is on the slow side, but not exaggeratedly so. Ok, I based these calculations on Nikon's spec of 40 sec per frame scans. Of course, I assumed this was for full res 4000 dpi so scanning at less than that would speed things up somewhat. Also, this is 35mm so 16mm would theoretically halve the time. I presume.
Here's my calculation: Say for a 10 minute short, that's 14400 frames (60sec x 10 x 24fps). At 40 sec/frame, that would take 160 hours or about 7 days of non-stop scanning. Practically, I'd say maybe 30 days to work on it with about 5 hours dedicated each day. (Not quite the months and months you quoted, Matt, but you were either using a different (albeit slower) scan time or calculating based on a longer short film.)
Yea, it is still a bit of a tedious process and would require quite a bit of dedication and mind numbing persistence, but hey, for personal experimental stuff, it's a possible option. All this of course disregards the time needed to correct for registration, which in my opinion, is the bigger problem.
Has anyone actually been crazy enough to have tried this though, I'm wondering? :P
Edited by Tim Shim, 19 May 2006 - 11:21 PM.
#5 Dan Salzmann
Dan Salzmann
  • 1143 posts
  • Paris, France
Posted 22 May 2006 - 02:25 AM
Yes but that does not inclue the time it takes to cut the film into strips and align them into the film holders.
Some kind of auto-fee system so you could keep the film on cores woul be great but also some major if not impossible tinkering with the scanner.
#6 Greg Gross
Greg Gross
  • 869 posts
  • Harrisburg,PA
Posted 22 May 2006 - 10:20 PM
Nikon provides a 16mm filmholder for the CoolScan 9000 ED(FH-816). From what I'm looking
at on line its only available for 9000 ED. Workflow:1. Choose adapter holder,2. Insert adaptor,
3.Start up Nikon software,4. Insert film holder,5. Select type film,6. View thumbnails,7. Display
a preview image,8. Adjust settings, 9. Adjust image quality, 10. Select image to scan, 11. Scan
and save images, 12. Eject the film. Cannot find anything about registration with the 16mm film
adaptor. Of course you would be using Nikon ED glass.
Greg Gross
#7 Bryan Darling
Bryan Darling
  • 227 posts
  • Sacramento, CA
Posted 22 May 2006 - 10:36 PM
I think the 16mm strip adapter could be for 16mm still camera frames not motion-picture frames. Meant for such cameras as the Minolta 16 series. I could be wrong. It would make more sense to use something like the JK optical printer with a digital still camera attached such as Canon or Nikon DSLR. They actually advertise their new printers for this person.
As for the time it'd take in comparison to a 35mm frame. Keep in mind that 16mm is about a 1/4 of the size of 35mm.
#8 Greg Gross
Greg Gross
  • 869 posts
  • Harrisburg,PA
Posted 22 May 2006 - 10:43 PM
Yes,
Thank you and I do not know. Could not find anything at web site.
Greg Gross
