ARRI 16SR3 PITCH ADJUSTMENT
9 replies to this topic
#1 weiming
weiming
  • 13 posts
  • 2nd Assistant Camera
  • singapore
Posted 20 May 2006 - 11:29 PM
according to the SR3 pdf manual: 'with the new pitch adjustment you can adjust the camera to optimise the running noise level when different types of film stock are used.'
what does adjusting the pitch physically change, that reduces the running noise level?
does using different film stocks in the SR3 create diferent noises/ noise levels?
Anybody have any idea?
weiming.
#2 Adam Frisch FSF
Adam Frisch FSF
  • 2026 posts
  • Los Angeles, USA
Posted 21 May 2006 - 03:32 AM
Basically how far in the pulldown claw grabs the sprocket.
#3 Annie Wengenroth
Annie Wengenroth
  • 653 posts
  • Sound Department
  • Brooklyn, NY
Posted 21 May 2006 - 08:41 AM
Actually, it's the angle (the pitch!) of the claw, not necessarily the depth. Because some stock might have a slight difference in the size or positioning of its perfs, you can adjust the pitch to compensate for this and reduce any noise that might occur as a result of the edge of the perf hitting the claw at an odd angle.
</geek>
I hope that helps. :-D
#4 Daniel Stigler
Daniel Stigler
  • 177 posts
  • Berlin, Germany
Posted 21 May 2006 - 09:42 AM
Black&White stock is thinner than color stock, because it has less layers and that causes the camera to run a little noisier.
#5 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 21 May 2006 - 02:25 PM
weiming.
FWIW the size of the perfs change as the cutter wears! Perfs cut at the start will be fractionally oversize and when the cutter is worn the perfs will be slightly undersize. The width of film also changes as I discovered in 1983 when some film kept jamming in the advance sprocket of an animation camera I owned. I had run about 250 400' rolls of stock with that camera. As the cutters wore the film got too wide!
Stephen
#6 Chris Keth
Posted 22 May 2006 - 11:35 AM
</geek>
Ding ding ding, we have a winner! There are a bunch of things that can cause raw stock to change size very slightly. Temperature, humidity, when in the run your roll was cut all affect the size and spacing of the perfs. The pitch adjustment is to help the camera run the quietest it can possibly run by adjusting for these minute changes in raw stock.
#7 weiming
weiming
  • 13 posts
  • singapore
Posted 28 May 2006 - 04:55 AM
okok
i understand clearly now. Thanks all for replying.
hmm, but something just occured to me. won't that mean that u have to roll the camera with film stock inside before u could adjust the pitch? in the process u could lose about 5-10secs of film, depending on how long u take to adjust...
guess it's supposed to be done sparingly.
#8 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 28 May 2006 - 05:08 AM
okok
You do have to run the camera to adjust for the pitch!
Stephen
#9 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 28 May 2006 - 06:34 PM
You can do it in prep with a dummy roll, but when you're on set and you adjust it you're going to have to waste a little film.
#10 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 30 May 2006 - 05:47 AM
Note that when someone has perf related problems, one should check that they were properly manufactured...
Sometimes, they are not just in a line and not at the good edge distance.
If you take a 2' length of film, fold it in 2 as to superpose the 2 1' lengths and check the perfs are perfectly at the same position...
THat happened to me with Fuji stock. It causes a bad registration pin test.
