Cleaning battery contacts
#1 Stuart McCammon
Stuart McCammon
  • 139 posts
  • 95010
Posted 22 May 2006 - 08:30 AM
Title says it all - my battery contacts are corroded - please help)
#2 markb
markb
Posted 22 May 2006 - 08:55 AM
I've heard if you use vinegar and baking soda and rub the contacts with cotton wool this should get the corrosion off.
#3 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 22 May 2006 - 09:32 AM
Brillo pads are probably a good option as well. At some point, you may discover that as you clean the contacts they sort of disappear or become too thin and break. I spent several messy hours with a soldiering gun fixing a couple of battery holders that had either a broken off spring or dissolved connector and was able to fix them. Not always the cleanest job but I got evey battery holder to work. The basic problem is there is not enough metal for the soldier to attach itself to.
#4 Robert Hughes
Robert Hughes
  • 873 posts
  • Sound Department
  • Minneapolis
Posted 22 May 2006 - 10:52 AM
I'd recommend against either vinegar/baking soda (gummy residue) or brillo pads (tiny steel hairs in the contact area). Try a Pink Pearl eraser or pencil eraser dipped in isopropyl alchohol. You want to clean off the corrosion with as little erosion to remaining contact metal as possible.
#5 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 24 May 2006 - 05:19 AM
Now he tells me. :ph34r:
#6 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 24 May 2006 - 09:41 AM
I favor the eraser for removing superficial corrosion. More severe cases might require a fine grit abrasive "emery" cloth.
#7 Erdwolf_TVL
Erdwolf_TVL
  • 104 posts
Posted 24 May 2006 - 12:25 PM
Commercial contact cleaner works nicely as well in some cases... It eats away the oxidation and lubricates the contact. This stuff is potent, so don't expect to buy it at the local convenience store.
Works better on contacts with a larger, flat surface area (not spring contacts)
#8 Dan Salzmann
Dan Salzmann
  • 1143 posts
  • Paris, France
Posted 28 May 2006 - 04:28 PM
I've got a retractible stiff metal wire brush that is about the same diameter as a medium size pencil lead. I got it years ago at Micro-Tools.
#9 Alan Duckworth
Alan Duckworth
  • 84 posts
  • Kelowna, B.C. Canada
Posted 17 June 2006 - 04:58 PM
I've tried everything over the years, and I now use a device called an "Oxide Scubber". You get them from electronics supply houses, and they look like a retractable pencil - even have a pocket clip - and cost about 10 dollars for the tool and two replacement scrubbers. The scrubber part is only about a quarter inch diameter, so it reaches anywhere, and they work like a damn. Just make sure the dust that is generated doesn't go anyplace important.
To finish the job, the electronics store can also sell you a liquid contact cleaner that incorporates a protectorant so that the corrosion does not come back. It must be good stuff - the container is labelled "EXTREME DANGER" !!!
