Jim, what is a test slice?
#1 Chris_Burket
Chris_Burket
  • 77 posts
Posted 24 May 2006 - 01:26 AM
Jim, I don't know if you still check this forum, but if you do...
I've heard you mention your "test slice" sensor many times. What exactly is that? Is it a small section of one sensor that you had made to test its capabilities? Or is it a full sized sensor "sliced" from a large wafer or something.... Obviously I'm no expert in sensor production.
I'm sure you are preparing the very best footage and stills for release this fall, but I am curious: Have you personally seen a still frame and/or 10 seconds of footage captured by the sensor and camera setup? I wouldn't expect you to release even a still until you have things perfected, but I'm wondering if its to the point where you have seen one, or shot some footage?
#2 Jim Murdoch
Jim Murdoch
Posted 24 May 2006 - 02:54 AM
And also, how come your "bespoke" super-35 sized sensor has an HDTV 16 x 9 Aspect ratio?
Why not 1.33:1 like the Arri D-20?
With CMOS sensors you have exquisite control over which pixels actually get used, allowing you to optimize the data rate and so on, so why not a full-frame unit so you can use anamorphic lenses.
#3 Balazs Rozsa
Balazs Rozsa
  • 25 posts
  • Digital Image Technician
Posted 24 May 2006 - 03:28 AM
That is correct.
#4 Chris_Burket
Chris_Burket
  • 77 posts
Posted 24 May 2006 - 12:12 PM
Hey, don't be hijacking my thread. Start your own. So back to the test slice thing....
#5 Jim Jannard
Jim Jannard
  • 361 posts
Posted 24 May 2006 - 12:24 PM
Correct. It is a small section of the large sensor to test both the sensor design and pixel design. Since we are doing things quite a bit different from the current group of existing sensors, we needed to prove the concept (which we did).
#6 Chris_Burket
Chris_Burket
  • 77 posts
Posted 24 May 2006 - 06:35 PM
Cool, thanks for the info. So have you seen a picture (although it would not be full res), created from your test slice? Have they made a full sized one yet?
