Recommended 35mm adapters?
#1 Cameron Fraser
Cameron Fraser
  • 7 posts
Posted 05 June 2006 - 10:37 AM
Can anybody recommend a tried and tested set up for using 35mm lenses on an XL H1? Anybody had any notable success with this setup? I haven't seen a definitive adapter set up mentioned anywhere yet.
Cheers and thanks in advance.
#2 Douglas Hunter
Douglas Hunter
  • 356 posts
Posted 29 June 2006 - 01:13 PM
I guess my question would be why don't you consider the P+S Tecnik system as being tried and tested? Perhaps you don't like the spinning ground glass, that would make sense, anything else?
#3 Ed Moore
Ed Moore
  • 54 posts
  • UK
Posted 29 June 2006 - 05:26 PM
Try this link http://www.dvinfo.ne...searchid=545000, if that doesn't work, go to http://www.dvinfo.net/conf/, register then search the H1 forum for mini35: lots of people have posted lots of example footage. Other than the mini35 your options are limited to things like the Redrock Micro M2, which fit in FRONT of the existing 20x lens rather than replacing it a la the mini 35. There may be something out there I haven't noticed, 35mm-adaptors for 1/3" cameras is a notoriously fast moving and finickity field.
Ed
#4 John Benton
John Benton
  • 5 posts
Posted 12 July 2006 - 11:02 AM
Theres are tons,
I have heard good things about Dan;s
http://www.dandiacon...ewweb/index.htm
but withh the H1 I personally love the Letus35X-XL
it firts directly on the camera and has image flip !
http://www.adapterplace.com/
here is some test footage I shot with it
(mostly in 24f - so you will need VLC media player to play the raw .m2t files)
http://www.realm.cc/upload/benton/
#5 Peter Sensor
Peter Sensor
  • 10 posts
Posted 22 November 2006 - 11:37 PM
I HAVE USED THE P+S TECHNIK MINI 35 WITH A CANON H1 W/ CANON STILL PRIMES AND HAVE HAD EXCELLENT RESULTS. YOU CAN SEE THE FOOTAGE AT - www.bellproductionservices.com/demo and click on "Digital Cinema" For more info on P+S contact Chris @ ZGC.com. for more info on alternative lensing -
try RPLENS.COM - best of luck.
