Is MiniDV to Super 16mm possible?
#1 Isaac Chung
Isaac Chung
  • 36 posts
Posted 10 June 2006 - 03:40 PM
In mixed media productions where DI is not an option, is it possible to transfer mini-DV to Super 16mm negative for inclusion in the AB roll? Please let me know what the options are for mixing in a 5% DV and 95% Super 16 production. Thanks,
Isaac
#2 Kevin Masuda
Kevin Masuda
  • 209 posts
Posted 11 June 2006 - 06:48 PM
Isaac
Correct me if I'm wrong everyone but isn't super 16 just the gate size?
#3 David Mullen ASC
  • 20069 posts
Posted 11 June 2006 - 07:38 PM
It requires you use single-perf 16mm filmstock to fit the extended gate's image onto the film.
The old EBR "Image Transform" device went to 16mm b&w separations from NTSC. There might be some kinescope companies that will transfer video to 16mm, maybe Super-16. There are a few companies that advertize video-to-16mm:
http://www.blackandw..... transfer.htm
DV.Film in Texas might do it.
http://www.dvfilm.com/
Most places with film recorders like a Celco or Arrilaser would probably recommend you transfer the DV to 35mm and then make an optical printer dupe to Super-16 as needed.
Since Super-16 is not intended as an end destination, but is meant either to be transferred to video or blown-up to 35mm, your best bet is to leave the DV footage in video until after the Super-16 project has been blown-up to 35mm (even if done optically), and then splice in the DV-to-35mm material into the 35mm IN.
#4 Michael Collier
Michael Collier
  • 1262 posts
Posted 11 June 2006 - 08:46 PM
I'm confused, how are you planning on presenting this. You say 95% super-16, so I assume you will be projecting it for a large audience, if you do it on film are you going down to a matted 16 frame or are you blowing up to a 35mm frame? Or are you telecining the whole thing and presenting it on tape?
#5 Isaac Chung
Isaac Chung
  • 36 posts
Posted 11 June 2006 - 09:50 PM
I mean to say that 95% of the filmed footage is in Super 16mm, and 5% is filmed in DV. Thanks for the responses--I'll contact those post houses tomorrow-
