500T exposed as 50D (oops)
31 replies to this topic
#1 Erdwolf_TVL
Erdwolf_TVL
  • 104 posts
Posted 13 June 2006 - 04:48 PM
A mistake I am unlikely to make again... only looking at the first two digits of a package before loading it.
Fortunately, I'm still learning, so this could be considered "school fees"
Question, though. Should I even bother having this processed?
Perhaps underprocess this (pull-processing, right?)
The colour balance I could correct digitally in telecine, but this won't do me and awful lot of good if the film is completely black...
Posted 13 June 2006 - 05:50 PM
That's about 3 1/3 stops overexposed, which is not great but may be recoverable. I'd pull-process by one stop and then color-correct the rest of the way down. Who knows, you may like the results...
Of course, this also means that you shot without the 85B filter, so you'll have to correct for that as well.
#3 Erdwolf_TVL
Erdwolf_TVL
  • 104 posts
Posted 13 June 2006 - 06:04 PM
If this works out I'll be very impressed...
Thanks for the feedback!
#4 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 13 June 2006 - 06:05 PM
Learning what different unexposed emulsions look like is your last line of defense, especially if you ever use recans. The emulsions of daylight film, especially 50D, look distinctly different from tungsten emulsions, such as 500T. It will help to snip off a short section of different stocks that you use, just to keep as a reference.
#5 Erdwolf_TVL
Erdwolf_TVL
  • 104 posts
Posted 13 June 2006 - 06:15 PM
I never thought of this... Thanks!
#6 Mark Dunn
Mark Dunn
  • 2667 posts
Posted 14 June 2006 - 04:22 AM
Don't forget to keep the snippets in the dark.
#7 Adam Frisch FSF
Adam Frisch FSF
  • 2027 posts
  • Los Angeles, USA
Posted 14 June 2006 - 07:34 AM
A good DP friend of mine encountered exactly the same thing - the 500T and the 50D have almost the same color on the tape that seals the cans (and often go on the mag), so it's easy to make a mistake like the clapper/loader did on this occasion. He said it'd be unrecoverable in telecine and I said it wouldn't. I was right. However, that doesn't mean it necessarily is usable - it's probably quite grainy in the highlights. Film has tremendous latitude.
#8 K Borowski
K Borowski
  • 3905 posts
Posted 14 June 2006 - 08:06 AM
Agreed, I'd pull one stop. I did something similar a while back, I overexposed 3 stops because of a silly goof with the light meter. Your problem with pulling more than one stop is that film can get streaky if the developing time is too short. I forget how long ECN-2 is in the developer bath, but rule of thumb is not to go much below 4 minutes in developer. To give you a similar analogy in still photography, I processed a roll of C-41 from one of those disposable cameras. Friggin' Kodak puts 800 speed film in a camera designed for underewater, eseentailly daylight, use, which boggles my mind. These negatives were THICK, probably at least three stops overexposed, but other than REALLY long printing times and some crunchy highlights, they were quite printable. In a telecine, this density would probably cause some problems, but nothing too tremendous. Now, IIRC, 500T is only a 320 film in daylight,, so you are, in effect, only 2 2/3 stops overexposed. Because of all the overexposure, you have "burned in" enough detail in the C, Y , and M layers that you don't have to worry about the color shift too much, becuase there is going to be more than enough detail in each layer. So with a 1 stop pull, you're left with 1 2/3 stops over. That is quite useable. I regularly overexpose film a full stop. You may not even want to get the pull. Perhaps do a clip test to determine?
Regards,
~Karl Borowski
#9 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 14 June 2006 - 08:46 AM
The suggestions to pull process by 1 stop is a good one, and should help keep the densities within a reasonable range for printing or transfer. Since the processing machine is usually run faster to "pull" a process, pulling more than a stop may result in tail end solution and wash times that are too short.
Even with the overexposure and incorrect filtration, you will likely get a usable image, perhaps with a bit of highlight compression. The very dense negative may give a bit more noise in some telecines.
The Kodak VISION2 Color Negative films have remarkable exposure latitude, especially for overexposure. B)
As mentioned by others, the color of the raw stock emulsion varies with film type, due mostly to different levels of absorber dye. Although the color of the emulsion can be a guide, it is NOT a sure way to positively identify a particular film type. And as mentioned, raw stock exposed to light will eventually darken and change color, so don't use old snippets.
#10 Sam Wells
Sam Wells
  • 1751 posts
Posted 14 June 2006 - 09:40 AM
It's a effective 320 speed film in daylight IF you use an 85 filter which he didn't have on.
-Sam
#11 K Borowski
K Borowski
  • 3905 posts
Posted 14 June 2006 - 12:30 PM
-Sam
Sorry, you're right Sam. There is going to be a slight speed loss due to the color mismatch ( maybe a third of a stop or less) because the tungsten balanced stocks are more sensitive to red and less to blue than their daylight balanced counterparts. I was thinking of B&W for a moment there. Daylight balanced B&W is supposed to be exposed a fraction of a stop more in tungsten light (without a filter) than in daylight, so likewise the same would hold true for color.
Regards,
~Karl Borowski
#12 David Mullen ASC
Posted 14 June 2006 - 12:37 PM
Actually that's backwards -- because tungsten light has an excess of red and a deficiency of blue, the blue layer has to be MORE sensitive to light to compensate, hence why it's grainier than in daylight-balanced stocks. So one of the effects of shooting tungsten-balanced stock in daylight without the 85B filter is that the blue layer is going to get overexposed more than the red layer.
#13 recans
recans
  • 4 posts
Posted 14 June 2006 - 01:21 PM
"...the 500T and the 50D have almost the same color on the tape that seals the cans..."
Anyone remember when ALL the Kodak stocks had the same color yellow tape?
#14 K Borowski
K Borowski
  • 3905 posts
Posted 14 June 2006 - 01:43 PM
Anyone remember when there was only one color negative stock?
#15 David Mullen ASC
Posted 15 June 2006 - 03:23 AM
I wish Kodak would avoid numbers that when handwritten, look like another stock's numbers. Back in the days of EXR 100T 5248 and EXR 500T 5298, I got a mag from the loader that was labelled sloppily "5248" but color-taped for high-speed 5298. I asked the loader which was it and he couldn't remember.
Over the years, the problem has occurred with 5247 and 5297, 5248 and 5298, 5274 and 5279...
So learn to write your 4's and 9's clearly!
I also did a film where the flashbacks were Kodak 5277 but the modern scenes were on Fuji 500T 8572 (plus two other Fuji stocks). I always referred to the Kodak as "77" and the Fuji as "500T" to the camera assistants, but one day I asked for "77" and they loaded 8572 because the assistant thought I was asking for "72" -- even though I never asked for that film by that number. Luckily it just meant that the 500T stock was exposed at 250 ASA, which is what I was planning on exposing the '77 at for that scene. But it did cause a shift in look for that particular flashback.
It's also a little tricky if you shoot a movie on both Fuji 250T and 250D stocks because it's hard to hear the difference between "T" and "D", so I try and call out the stock numbers in that case, and I double-check to make sure the right mag is on the camera.
#16 John Holland
John Holland
  • 2273 posts
  • London England
Posted 15 June 2006 - 03:36 AM
Yes i am afraid i can ,very old, 5254 was only Kodak colour neg ,when i started . john holland.
#17 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
Posted 15 June 2006 - 08:32 AM
Yes, 5254 was the stock of choice when I started working for Kodak on June 8, 1970. I can remember all the R&D activity that led to 5247 and the ECN-2 process a few years later.
#18 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 15 June 2006 - 08:57 AM
John,
I think 5247 was the only Kodak Colour negative when I started in the late 1970's. When did Fuji & Agfa start making motion picture film?
Stephen
#19 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
Posted 15 June 2006 - 09:24 AM
John,
Stephen
Here is a link to a timeline of motion-picture films offered by the major film manufacturers:
http://www.cinetech....cktimeline.html
Kodak first supplied film for Edison and Dickson's motion picture experiments in 1891:
http://www.kodak.com...ml?pq-path=2699
Here is the chronology of Kodak motion-picture films:
http://www.kodak.com...=0.1.6.26&lc=en
#20 David Mullen ASC
Posted 15 June 2006 - 12:05 PM
I know (or believe) that Sovcolor and Fujicolor, etc. derived their early formulation from seized Agfacolor technology after WW2. I'm surprised that the timeline doesn't mention a color negative Fuji MP stock until the late 1960's.
Just from reading "American Cinematographer", some (very few) TV shows in the 1970's used Fuji color negative for cost reasons. There was some complaints about manufacturing consistency in terms of perfing / slitting, etc. Fred Koenekamp tested Fuji for "Islands in the Stream" (1977) and liked the softer quality it had, but studio concerns made him opt for Kodak with more diffusion.
So the first significant use of Fuji that I read about was for the period scenes in "Somewhere in Time" (1980), shot by Isadore Mankofsky. But before that, I know that "Farewell My Lovely" (1975) was shot on Fuji by John Alonzo.
Then Fuji come out with the first faster (than 5247) color negative stock, a 250T stock, in 1980 and there was a big jump in the number of productions shooting Fuji -- films like "Sharkey's Machine", "Das Boot", "Star Trek II", "Room with a View", "Legend", etc. Kodak followed up with their 250T stock, called 5293 (not to be confused with EXR 200T), about a year and a half later.
