Depth of Field Tests DVX-100/DSR-450/Pro 35 w/Prime
#1 Jeff Regan
Jeff Regan
  • 38 posts
Posted 13 June 2006 - 09:24 PM
I did some tests to see the depth of field differences between a 1/3" CCD imager vs. a 2/3" CCD as well as a 2/3" with P+S Technik Pro 35 35mm adapter and 35mm cine prime lens. I used a Panasonic DVX 100A, Sony DSR-450WS with Fujinon 15X8 zoom lens and DSR-450WS with Pro 35 adaptor with Zeiss 65mm Super Speed T1.3 prime lens.
The DVX 100A had a focal length of 20mm at F2.8, the DSR-450WS had a focal length of 30mm at F2.8 and the Zeiss prime was at T1.3. Below are the DVX-100 and DSR-450WS with standard lens......
Jeff Regan
Shooting Star Video
www.ssv.com
Edited by Jeff Regan, 13 June 2006 - 09:28 PM.
#2 Jeff Regan
Jeff Regan
  • 38 posts
Posted 13 June 2006 - 09:38 PM
The thumb nail in the post above on the left is the DSR-450WS w/Fujinon 15X8, on the right is the DVX-100A,
and I can't seem to post the 450 w/Pro 35 and prime due to forum bandwidth limitations.
Jeff Regan
Edited by Jeff Regan, 13 June 2006 - 09:43 PM.
#3 Hans Kellner
Hans Kellner
  • 56 posts
  • Northern California
Posted 15 June 2006 - 12:06 PM
Thanks for the comparison. Interesting to see the differences.
#4 Joshua Provost
Joshua Provost
  • 71 posts
Posted 15 June 2006 - 02:16 PM
Jeff,
Interesting. There is a big difference, though, between the DOF of F2.8 and with the lenses wide open, which is probably F1.6 on these cams. Would like to see a shot at F2.8, and a shot at F1.7 with 1.5 stops worth of ND on there. Of course, the relative DOF remains the same: twice as much DOF for the 1/3" cam.
Josh
#5 Jeff Regan
Jeff Regan
  • 38 posts
Posted 16 June 2006 - 12:51 AM
Jeff,
Josh
Josh,
I chose to shoot both the regular lenses at F2.8 because the DVX 100A has an F2.4 max. F-stop, and while
the Fujinon 15X8 has a F1.7 max F-stop, I don't normally shoot wide open due to portholing, softening, fringing, and light level fall off, plus the DVX-100A can't open beyond F2.4, so F2.8 seemed like a good compromise.
The Zeiss Super Speeds are optimized to shoot at T1.3, so it made sense to shoot at that exposure, especially since the Pro 35 has approx. one and a half stops of light loss.
I wish I could post the Pro 35 thumbnail. You can see it at www.dvxuser.com, under "Other Cameras", but
you'll have to register.
Jeff Regan
Shooting Star Video
www.ssv.com
