Mattebox
#1 Luzer
Luzer
Posted 15 June 2006 - 08:18 AM
Hi all
This is my first post here and I would like to ask a question. The 3x3 mattebox that comes with the SRII, what's the diameter of its back mount?
#2 Luzer
Luzer
Posted 16 June 2006 - 04:57 AM
Anyone knows the answer to the above? Hmm, maybe I should ask the question in another way. The lens used on the SRII is a Zeiss 10-100 but Im not sure of its front diameter. Anyone knows?
#3 Robert Glenn
Robert Glenn
  • 247 posts
Posted 17 June 2006 - 11:26 AM
not sure but you can check chrosziel's website.. they have a pdf catalog that has a list of most major lenses and their outer diameter
Edited by RobertNC, 17 June 2006 - 11:27 AM.
#4 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 17 June 2006 - 02:18 PM
The front diameter of the Zeiss 10-100 T2 Mk1 lens is 80mm. The front diameter of the Zeiss 10-100 T3.1 lens is 75mm. Those are the only two that I know the front diameters for.
-Tim
#5 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 18 June 2006 - 01:19 PM
The later 10-100 T2 Mark2 has an 87mm front.
If you have a 3x3" mattebox, that is really ancient history and I question if it will even cover the lens at 10mm. It certainly isn't worth the cost of investing any filters or accessories for it. Much better to get a 4x4 mattebox which will cover fine and you can both purchase and rent filters in the size commonly. There are many inexpensive models out there now because this is the size preferred for most of the MiniDV camcorders.
