Edius Pro Rendering Problem
#1 Gary Lemson
Gary Lemson
  • 155 posts
  • Santa Cruz Mountains
Posted 17 June 2006 - 01:08 PM
I have the latest demo version of Edius Pro. When I render a clip selection, the program terminates, and I end up back at the desktop. If I select "render and add to timeline", then the process seems to complete and the rendered clip (copy) is added to the next video track (less audio). I can certainly work around this by placing the audio with the rendered clip. However, it's not the ideal solution.
Any ideas why I'm getting kicked out when doing a normal render?
#2 Bryan Darling
Bryan Darling
  • 227 posts
  • Sacramento, CA
Posted 17 June 2006 - 02:43 PM
I use the Eduis NX system with Edius Pro v3.61. I can't recall running into this issue, but might I suggest the forums on Canopus. I think that would be a better resource for your problem. It could have to do with the codec of the original file you are trying to render into a new codec. Have you just tried a plain render to file? Once rendered, the program places it in the file bin. Then drag that from the file bin into the timeline. This might help in tracking down the issue. I'd try that and see what happens, then put a post your question with results of tests you've tried onto the Edius forum.
