Footcandle metering technique
#1 Jann Doeppert
Jann Doeppert
  • 4 posts
  • Ludwigsburg / Stockholm
Posted 29 June 2006 - 11:52 AM
I recently read about a metering technique Gerald Hirschfeld uses. (Please correct me if I´m wrong)
In "controlled" indoor scenes he´d have a flat diffusor (footcandle) reading of the key light. Using a chart he´d get the T-stop to use.
All other lights (fill, back,..) are set only using the eye (and a contrast viewing glass).
Pro´s are of course fast and easy set-up...
Does anyone use this technique? What are the cons?
#2 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 29 June 2006 - 03:20 PM
If you base your exposure only on the key light, and then add fill, you will be getting more than a "normal" exposure --- If your key is 100 footcandles, and you add 50 footcandles of fill, you are getting a total of 150 footcandles on the fully lit areas of the subject. That's why incident light meters with a "dome" collector that integrate all the lights are widely used.
