Shooting B&W with dvx
9 replies to this topic
#1 Thomas Fant
Thomas Fant
  • 24 posts
Posted 02 July 2006 - 03:33 PM
I will be shooting a short horror film next weekend with a dvx 100, and the director wants black and white, so the color wil be removed in post. Anyone done this before ? Any special secrets I should know, besides basic stuff like shooting with a red filter to show clouds ? It seems like it will be pretty straight forward, I was just wondering if anyone has had good or bad experiences with this type of thing ?
#2 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 02 July 2006 - 04:39 PM
I've done it with the SDX900 and other video systems. Definitely monitor in B&W (just turn the chroma down on the monitor). Let your eye be your judge of the image.
#3 freddie bonfanti
freddie bonfanti
  • 315 posts
  • LONDON
Posted 02 July 2006 - 05:39 PM
hey
when i shot the big forever i shot it in bw (.http://www.cinematography.com/forum2004/index.php?showtopic=14486)..i preferred to achieve the best bw quality on the spot. i always think that when you light for bw you need to see the picture in bw, i cant do it in color. its just my idea but in my (small) experience it always worked. its like if bw has got its own texture that color doesnt have, therefore id suggest you to shoot it in bw in camera
good luck
freddy
#4 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 02 July 2006 - 05:53 PM
Can the DVX do B&W in camera? I didn't think it could.
I agree about lighting and monitoring in B&W, but if the camera can't desaturate internally then B&W monitoring is the next best thing.
#5 Hans Kellner
Hans Kellner
  • 56 posts
  • Northern California
Posted 02 July 2006 - 10:15 PM
True. The DVX can't fully desaturate in camera.
Also, you should play with the scene settings to crush your blacks and bring the color down.
Try:
1. master ped way down (-8)
2. detail down (-3) and vdetail down (-2)
3. gamma low
4. knee low
5. matrix normal
6. chroma level down (-5)
These values are just suggestions from playing with B&W on my DVX. Adjust until you get a L&F that works for you and for your lighting. Oh, and with noir, lighting is so important so don't fudge on that.
#6 Michael Collier
Michael Collier
  • 1262 posts
Posted 02 July 2006 - 11:57 PM
Try:
3. gamma low
4. knee low
5. matrix normal
please dont try that. First the pedistal should not be lowered to get the saturation out (it may have that effect but it would make things much more difficult) same with gama and knee. Its not the sort of settings you should mess with to get the chroma out (especially when post B/W is fine)
I would shoot regular, but with a B/W monitor to preview. Then a cool tip in post is add color correction before adding the desat. I know it sounds weird, but think of it like adding a red filter, it darkens greens and blues right? well with RGB color manipulation prior to BW you can get razor sharp control over the effect. Gives a ton of options.
#7 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 03 July 2006 - 12:15 AM
I agree about simulating colored filters in post, although you could still use filters on the camera if you're more familiar or comfortable with that. Suffice it to say that shooting in "normal" color and normal dynamic range gives you the most amount of information to play with in post.
I also agree about not crushing the blacks in camera, unless you know that's the look you're going to use. The only "fly in the ointment," so to speak, is that increasing the contrast too much after the image has gone through DV25 compression is that it can start to reveal artifacts like noise and banding of gradients. I think a reasonable approach for increasing contrast with a highly compressed format is to adjust the image "half way" in camera and the rest of the way in post. That way you're not completely limited by either the camera or post.
#8 Peter J DeCrescenzo
Peter J DeCrescenzo
  • 620 posts
  • Portland, OR, USA www.peterdv.com Blog: http://herefortheweather.wordpress.com/
Posted 03 July 2006 - 11:49 AM
In addition to the good advice here, just in case it hasn't already been mentioned: Especially if you plan to perform in-camera "special effects" (e.g.: B&W, and so forth), you won't be able to judge results using the camera's built-in LCD screen or viewfinder.
Much, much more accurate than these would be a properly-calibrated, professional, CRT monitor. In general, CRT monitors are much more accurate than LCD monitors, unless you use an LCD which costs several thousands of dollars (and even then ...). As previously suggested, you may choose to turn down (or turn off) the monitor's color (chroma) control, but otherwise the monitor should be calibrated correctly at all times.
#9 Hans Kellner
Hans Kellner
  • 56 posts
Posted 03 July 2006 - 06:14 PM
Yes, I agree to not attempt to remove saturation in camera. My settings recommendations above are to adjust the image so that the blacks will not appear milky and the image, when desaturated in post, will look good. These settings are based on my experience with the camera and creating B&W in post.
But, I may have goofed and been able to create better results :( Will experiment again at some point in time.
#10 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 03 July 2006 - 07:05 PM
It is always a matter of fine-tuning the controls involved for the desired result. There's no single, definitive procedure that will work in all situations, for all desired results.
