Super16 zoom lenses
#1 Josh Silfen
Josh Silfen
  • 53 posts
Posted 12 July 2006 - 03:48 PM
I'm looking for advice on Super16 zoom lenses. All the ones I've worked with have been quite old. I know that there have been great strides in zoom lenses recently with the Optimo series for 35mm, but are there similar sharp modern zooms out there for Super16 as well? Specifically, I'd like to know what Super16 zooms have the best anti-flare coatings and least breathing. Thanks a lot.
-Josh Silfen
#2 Chris Burke
Chris Burke
  • 1720 posts
  • Boston, MA
Posted 12 July 2006 - 04:21 PM
-Josh Silfen
check out the newer Canon Super 16 zooms. In my opinion they are great lenses.
chris
#3 Chris Keth
Posted 12 July 2006 - 06:36 PM
-Josh Silfen
Well, 35mm lenses work perfectlky well for shooting super 16, or regular 16 for that matter. I'm fond of the newer Cooke zooms, personally. The canon super 16 zooms Chris mentions are nice as well. The good standby zeiss 10-100 is a favorite of mine, as well, even being a bit older lens.
#4 Wendell_Greene
Wendell_Greene
  • 545 posts
Posted 12 July 2006 - 07:43 PM
I'd personally recommend you test the Angieneaux 7-81mm zoom.
#5 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 12 July 2006 - 11:19 PM
I've used both the Canon 8-64 and the Canon 11.5-137 pretty extensively, and they're both great lenses.
#6 Rik Andino
Rik Andino
  • 783 posts
  • Electrician
  • New York City
Posted 13 July 2006 - 02:01 AM
I second that on the Canon zooms they're very sharp...
And the color rendition is good.
My only qualm with them is that they're huge...
They add at least 5 pounds to the camera outfit.
I wonder if they're any good light-weight zooms for S16?
#7 Stephan Schuh
Stephan Schuh
  • 14 posts
Posted 13 July 2006 - 12:22 PM
Hi!
I have just taken a look on a couple of zooms and primes on a projector. Canon 8-64 is still my favourite and looks quite sharp above 2.8 and a half. The Canon 7-63 looked a bit worse, although it is the newer Canon Zoom. If you don´t shoot wide open, the resolution is generally good, even compared to Zeiss Ultraprimes. Flaring and distortion are the major problems of zooms in general. At 16mm focal lenght the distortion of the 8-64 is at its worst. At 12 and 20 mm it is tolerable. Not much you can do about flaring. If the lens is in a bad shape it is getting worse. So check that your Zooms are nice and clean. Of course the Ultraprimes have a better performance at the edge of the frame, but they are expensive and make shooting slow. Ah - and the 8-64 is hardly breathing, I think even less than the Ultraprimes. I wouldn´t shoot on them for 16 unless it is getting really dark and you want to use them wide open.
Best regards from Germany!
Schuh
