Arri SR
7 replies to this topic
#1 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 17 July 2006 - 03:05 PM
I apologize for not knowing the name, but we have an Arri SR that is missing the piece that plugs the batteries into the body. Could anybody tell me what its called (so I can quit sounding like an idiot) and also where to find a replacement part?
Chad
#2 Nathan Milford
Nathan Milford
  • 692 posts
  • New York, NY
Posted 17 July 2006 - 03:26 PM
On-board battery adaptor.
Those things are super hard to come by, aftermarket.
#3 Mike Welle
Mike Welle
  • 125 posts
Posted 17 July 2006 - 03:59 PM
This might help if you can't find the adapter:
http://www.longvalle...com/adapter.php
Mike Welle
Chad
#4 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 17 July 2006 - 04:06 PM
Chad
Nathan is right, and they are also usually obscenely expensive. They turn up on eBay from time to time, and I do believe you can still buy one from ARRI, just be prepared to pay through the nose.
You can use a Bescor 12 volt battery belt that has the 4 prong XLR (Clive Tobin used to sell them) and that plugs right into the back of the camera, no adapter needed. And that whole battery, brand new, is going to cost you less than that little adapter, and that battery belt will let you shoot many more mags than the ARRI on-board batteries.
-Tim
#5 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 17 July 2006 - 04:14 PM
Cool, that helps. I've made a few calls and yes, they are obscenely expensive. We have a plate that will work with anton bauer batteries, but it's kind of cumbersome. I'll look into the belt. Thanks!
#6 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 17 July 2006 - 05:32 PM
The problem with not using an onboard is that when doing handheld the camera can become more front heavy, especially when using a zoom. Otherwise, a block or belt battery is fine.
#7 Bernhard Zitz
Bernhard Zitz
  • 342 posts
  • Zürich, Switzerland
Posted 18 July 2006 - 04:38 AM
if you want to use the original batteries you could build an adapter by yourself...
camera input is 4pin XLR,
Battery output is the same like the plugs you have on AC to DC adapters[attachment=1343:attachment] , just embeded in that square hole...
get a 4pin XLR female to plug to the camera
to plug on the battery something like this[attachment=1341:attachment] or this [attachment=1342:attachment]
i can't remember the diameter, just go to your local electronic parts store and test what fits...
---check polarity before running your camera---
if you take two 7.2 LiIons in serial (from a DVcamcorder for ex.) you'll get 14.4V, it's very lightweight and you don't have all the disadvantages of NiCads
cheers, Bernhard
#8 Bernhard Zitz
Bernhard Zitz
  • 342 posts
Posted 18 July 2006 - 04:53 AM
sorry the picture attachments for the battery plugs did not work[attachment=1346:attachment] [attachment=1347:attachment] [attachment=1348:attachment]
