anamorphic adaptor
7 replies to this topic
#1 Murthy SNB
Murthy SNB
  • 27 posts
  • Bangalore INDIA
Posted 18 July 2006 - 11:08 AM
are there Anamorphic adaptors availobale to 16mm cameras?
so that finally a 35mm anamorphic release print be made
for theatrical release?
#2 Matthew Skala
Matthew Skala
  • 44 posts
Posted 18 July 2006 - 12:52 PM
JDC, a rental house in Wilmington, NC & London has a set of 16mm anamorphic lenses: www.joedunton.com
give them a call, mention my name: Matthew Skala (they may not remember me but I am trying to get my name out there, just tell them I referred you.)
#3 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 18 July 2006 - 02:03 PM
Look for Kowa 16H/8Z on eBay. You'll have to make your own mounting bracket.
I know someone who used one on a Nikkor on an Eyemo stunt camera in a Jackie Chan rodeo movie. The results were quite good.
You'll have to focus both the backing lens and the attachment.
---LV
#4 Bernhard Zitz
Bernhard Zitz
  • 342 posts
  • Z├╝rich, Switzerland
Posted 18 July 2006 - 04:05 PM
this http://www.lonesomecowboys.be/ was done with a Kowa 16-H on Eclair NPR, it was for video only, check under videos
in wideangle you'll get some barreldistortion, 20mm (like 10mm in non-anamorphic) is the widest you can go without vignetting. The Kowa 16-H eats 1/3 stops, in 16mm 2x anamorphic is 2.66 wide, in 35mm you have to crop to 2.35
Kowa 16-H is the same as Kowa 8-Z
#5 Murthy SNB
Murthy SNB
  • 27 posts
  • Bangalore INDIA
Posted 19 July 2006 - 10:09 AM
P S.
what will be the aspect ratio of the blowup release print,from the
16mm anamorphic neg to 35mm anamorphic blowup release print?
with regards,
#6 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 19 July 2006 - 01:12 PM
P S.
---It would be the normal C'Scope aspect ratio, 2.35/1, 2.4/1.
Use the sides of the TV safe area for framing.
---LV
#7 Murthy SNB
Murthy SNB
  • 27 posts
  • Bangalore INDIA
Posted 20 July 2006 - 10:51 AM
---LV
Thankyou Mr.LV but in the blowup print there will be top & bottom strips will be
there and the aspect ratio be only for the image area to be taken? is it not so?
Murthy
#8 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 20 July 2006 - 01:48 PM
Murthy
---it can be blown up to any size.
2.2x is the usual for regular16 to academy. In this case it would be 2.5X for regular 16 to full frame.
With the 2.2x the AR would be 2.66/1.
---LV
