shutter angle
#1 darryl walthall
darryl walthall
  • 10 posts
Posted 21 July 2006 - 01:58 PM
Can I achieve a sharper image, with less grain, by manipulating the shutter angle or speed ? And if so, do I open the shutter or close the shutter to help achieve a sharp , grainless image?
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 21 July 2006 - 02:22 PM
A smaller shutter angle will give a sharper image as the exposure time is reduced. For a grainless image shoot with a low speed film.
Last week I saw a film being shot with a Viper with a 90 degree shutter angle. The Images were sharp and grainless!
Stephen
#3 Bernhard Zitz
Bernhard Zitz
  • 342 posts
  • Z├╝rich, Switzerland
Posted 21 July 2006 - 04:43 PM
smaller shutter angle = less motionblur = sharper image (but strobe-effect)
smaller shutter angle = less light on film = more lamps (or higher asa)
or
smaller shutter angle = less light on film = to shoot wide open = softer image
if you don't have enough light you could be forced to use higher asa, that could result in more grain... or you might film wide open (f-stop wise) that could result in softer images...
#4 Chris Keth
Posted 21 July 2006 - 06:32 PM
No. Grain and sharpness of a film image is a product of the speed of the film and how you expose it.
What the shutter angle can do, on the other hand, is control motion blur. A 90 degree shutter opening will have less motion blur than a 180 degree shutter opening. It will also, however, show a greaterstrobing effect because the time between exposures is slightly greater. It will also require a stop more light because it yields an exposure time half of that of a 180 degree shutter opening.
