Oxbury Animation Stand Info
#1 Alexis Mayer
Alexis Mayer
  • 6 posts
  • Boston
Posted 21 July 2006 - 02:57 PM
I'm going to be shooting the credits for my film on an oxbury animation stand next week, I've never used an animation stand before, and I was hoping someone could recommend a few good human readable resources to study up on it before I go in there. I will have someone there explain everything to me initially, but I know I will get confused and I'd like to have some reliable references with me in case I run into any problems and no one is around to help. Thanks!
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 21 July 2006 - 03:44 PM
About the only book written AFAIK is:-
http://www.amazon.co...8...ce&n=266239
An Oxberry camera only runs at about 3 fps. Other than that its just a camera with good registration. What exactly do you want to do?
Stephen
#3 Alexis Mayer
Alexis Mayer
  • 6 posts
  • Boston
Posted 21 July 2006 - 04:02 PM
Stephen
Well I am shooting titlecards (credits really) using transparencies. I need to know basic things like how to meter the light, how many seconds to expose each transparency if I want 7 seconds of film for each card (knowing that it runs at about 3 fps helps with that question), could light leak happen because of something other than a leaky magazine. Also just any common problems and their solutions.
#4 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 21 July 2006 - 04:46 PM
An Oxberry with a Mitchell magazine will not leak light if you close the door of the camera! I have shot film with over 200 passes of the same film and never a problem.
An Oxberry will have a frame counter so if you want 7 seconds you need 168 frames. Time out your sound track first then you can shoot exactly to length without needing any editing!
Take a light reading of the lightbox. Because its white overexpose by 2.5 stops. The exposure is 1/6 sec. Often there is Poloriser on the lens by default, take it off or allow another 1.5 stops.
Stephen
#5 Alexis Mayer
Alexis Mayer
  • 6 posts
  • Boston
Posted 21 July 2006 - 05:09 PM
Stephen
Great! Thanks for all the info! I'm hoping the animation stand just looks a lot more intimidating that it really is.
~Alexis
#6 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 22 July 2006 - 02:41 AM
~Alexis
The controls will be minimal unless it has been fitted stepper or servo motors. Normally I would expect the following:-
Single frame button,
Cont run button
FRD/Reverse run
Buckle switch
Take up tension. Take care that the takes up's are moving!
Fade/dissolve In/out. Make sure the shutter is set to 170 degrees!
Capping shutter, must be open if fitted!
Frame counter
Stephen
