On-screen Plasma TV's...
9 replies to this topic
#1 Christian Vandervort
  • 10 posts
Posted 22 July 2006 - 12:37 AM
I'm a student preparing to shoot a 24p project with a Sony F900 starting 7/27, and there is a scene in which two characters watch an episode of "I Love Lucy". Is the Plasma TV we have for the scene going to cause any flicker or other undesirable effect if I just shoot it? (i was recently told that it wouldn't)
I would appreciate any advice
Thanks ahead of time
Edited by cvander, 22 July 2006 - 12:39 AM.
#2 Jim Murdoch
Jim Murdoch
Posted 22 July 2006 - 02:18 AM
It depends on the model. There's no particular reason a plasma screen needs to have its rows of pixels scanned in any particular order, and some manufacturers deliberately scramble the order to minimize flicker. Unfortunately, some others seem to do it more like a traditional CRT scan and you do get strobing effects.
The only way to find out is to shoot a test using a handycam or similar. If at all possible, use an LCD TV instead, they produce zero flicker.
#3 David Mullen ASC
Posted 22 July 2006 - 11:43 AM
I would think that from a Plasma screen what you're more likely to see is a hertz pulse, more like HMI flicker than a roll bar from a CRT screen -- in other words, if this is a 60 Hz power, probably the optimal shutter speed is around 1/60th. But since this is a pro video camera, you can just use the clear-scan (ECS) function to remove the visible pulsing in the monitor.
#4 Christian Vandervort
  • 10 posts
Posted 22 July 2006 - 12:43 PM
Well at one point I shot this TV successfully with a Canon XL2/ PS Technic Adapter at 24 p... is that any indication? (sorry I forgot to include this previously)
#5 Jim Murdoch
Jim Murdoch
Posted 23 July 2006 - 03:38 AM
That should be OK then. Incidentally, the P&S adaptor doesn't really make any difference for test purposes, you can just point the camcorder directly at the screen. The "shutter angle" should ideally be "180 degrees" in other words 20.8833333333333333 milliseconds! But again, this will depend on the model
#6 Jim Murdoch
Jim Murdoch
Posted 23 July 2006 - 03:50 AM
The first plasmas I ever saw were completely strobe-free, like an LCD. I don't know why the manufacturers changed their designs, but some of the later models do produce a roll bar like a CRT screen, although not as intense. After giving somebody what turned out to be the wrong advice, my only advice now is "Test!" or use an LCD if there is any choice in the matter. In any event, LCDs come up really well on film, are much lighter, and getting cheaper by the hour.
BUT! Don't use any sort of polarizing filter with an LCD as you may not get any picture at all! (As many a bright young advertising dude has found when he came up with the bright idea of using an LCD screen mounted on its side as an animated advertising billboard. If your potential customer is wearing Polaroid sunglasses, he don't see n'owt!) B)
#7 Bruce Greene
Bruce Greene
  • 571 posts
Posted 31 July 2006 - 01:12 AM
The last time I shot a Plasma (Panasonic model) there was pulsing like with an out of sync HMI lamp. We fixed the issue by shooting with a shutter angle of 144 degrees (Varicams let one select shutters like on film cameras). In the f900 use the syncro scan to find a shutter speed that gets rid of the flicker, probably close to 1/60th second.
#8 Christian Vandervort
  • 10 posts
Posted 02 August 2006 - 03:56 PM
Everything went as planned... thanks for the help guys
KV
#9 David Mullen ASC
Posted 02 August 2006 - 08:04 PM
KV
So what did you do? Did you have the adjust the shutter?
#10 Christian Vandervort
  • 10 posts
Posted 18 August 2006 - 02:46 PM
sorry for the long delay...one student shoot after another.
No, it ended up being quite easy. I did a quick test with the shutter ON at 1/48, and upon playback on an HD monitor- everything looked flawless.
Thanks again
