Lighting eyes- techniques
16 replies to this topic
#1 Joe Hemsani
Joe Hemsani
  • 15 posts
  • Mexico
Posted 25 July 2006 - 01:27 AM
Hello!! I am wondering how to light-up the eyes (meaning having a glow or reflection in the iris) of an actor.
What are the different techniques used in various situations as close ups, medium shots and moving shots (steadicam or dolly)???????
Thank you for your time and knowledge!!!
#2 Rik Andino
Rik Andino
  • 783 posts
  • Electrician
  • New York City
Posted 25 July 2006 - 02:42 AM
The easiest way is to have a big difussed source point at the actors face from a distance.
There are many many other ways..you're going to have to practice on your own to learn...
Good Luck
Edited by Rik Andino, 25 July 2006 - 02:42 AM.
#3 Ofer Dori
Ofer Dori
  • 6 posts
Posted 25 July 2006 - 02:44 AM
hi . using a frontal small eye lance lamp will do it . glow efect dosnt working from medium. s and longer because of the small eye surface in the fram.
#4 rajavel
rajavel
Posted 25 July 2006 - 01:47 PM
actually as Rik said....lot many ways...best is to experiment.....some may be
1) try the Cameo lighting.....from the stable of Kinoflo...its basically a ring light that
goes just over the lens of the camera....and lights the face beautifully....with an
interesting RING in the iris of the artist eye.
this is similar to the ring flash that the fashion photographers use!
2) try a big soft box......
3) try the soft box with EGG crates
4) try soft box with marking tapes on it....that can be passed of as window pane reflection in the iris
5) try a spot light practical...that is generally used in jewellery show room display .......can give
a bright sparkling effect on the eyes
6) try hanging a chinese lantern if it is an Extreme CU
7) and many more to experiment....let me know if u find anymore !
cheers!
rajavel
#5 Chris Keth
Posted 25 July 2006 - 02:36 PM
One really neat one is to place a very hard source on the same plane as the iris. It will actually light up the lens of the eyeball but not light the iris itself very much. It gives a very glassy, glowy look to the eye.
#6 Joe Hemsani
Joe Hemsani
  • 15 posts
  • Mexico
Posted 25 July 2006 - 04:46 PM
Thank you for the tips!!!
I will have to go and experiment these things.
I will deffinately try them out and will let you know how they worked and try to I find another way.
This technique is the one I commonly use and it does look really neat thank you.
Just one other question to rajavel... How do you place the cameo lighting on the lens?
cheers!
#7 rajavel
rajavel
Posted 26 July 2006 - 05:33 AM
get one cameo and its easy...u will figure it out .....its a ring form.....that can be fixed and insert the lens through it.....u might not b able to use the filter hood but....can use black wrap around lens....any filter can be stuck jjust for that shot.
rajavel
#8 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 26 July 2006 - 08:11 AM
You can also build what I would call a "ring-light" by getting a circular base and attaching lightbulbs around it, you can shoot through to nice effect, kind of a poor man's kamio. All the parts to make cost about $100.
Another thing you can do, and this would fall in the glamour lighting category, but using 4 chimeras, mount one above the lens, one below and one on either side. Gives a nice large source soft light effect, and a cool cross pattern in the eyes.
#9 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 26 July 2006 - 08:12 AM
#10 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 26 July 2006 - 08:13 AM
#11 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 26 July 2006 - 08:14 AM
#12 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 26 July 2006 - 08:15 AM
#13 G McMahon
G McMahon
  • 161 posts
Posted 26 July 2006 - 08:54 AM
Hold a bunch of fairy lights close together in a close up to give a thousand reflections in the eye balls. Andrew Lesnie ACS, ASC used this technique for quick fill and to give an ethereal quality to Kate Blanchet on Lord of the Rings.
Graeme
#14 Sing Lo
Sing Lo
  • 39 posts
Posted 26 July 2006 - 03:25 PM
Graeme
What is a bunch of fairy lights??? Rope lights coiled up like a pancake???
#15 G McMahon
G McMahon
  • 161 posts
Posted 26 July 2006 - 11:16 PM
Fairy lights, white christmas lights. The type that has no covers on them. And I believe he used them like you were holding a bunch of flowers or pencils in a hand.
Graeme
#16 Joe Hemsani
Joe Hemsani
  • 15 posts
  • Mexico
Posted 28 July 2006 - 12:25 AM
Thanks for the tip on the home made kameo light, it sounds easy and simple to manufacture!ª!!
Also today I went over to the rental house and askd for the kameo light and saw it. It´s really cool and easy to use. Has a nice quality of light.
Graeme
Well this is a great Idea hadn´t thought of it, Im gonna have to go and test this!!!
thanks
Edited by joeh, 28 July 2006 - 12:26 AM.
#17 EricUlbrich
EricUlbrich
  • 31 posts
  • Orange, CA
Posted 29 July 2006 - 04:44 AM
I think we are missing the point here. There are almost an infinte amount of ways to make a eye-light. I remember specifically a single tracking shot we did on "high school musical" from the disney chanel that consisted of a single tracking shot on a dolly down a high-school hall. For this shot we made an eyelight by attaching 4 two bank floro fixtures with kino tubes in a box pattern on the dolly. Then the camera is placed inside of this box and a general fill/eyelight was created. Kameo and Light panel lights are nice, but they are nice for only a certian situation, they are not an end all fix. Just remember think big, think soft and think balanced.
