That "Bluish" look.
7 replies to this topic
#1 sray
sray
  • 4 posts
Posted 29 July 2006 - 06:56 PM
Ok guys, please forgive my ignorance. I am a "newbie" when it comes to cinematography. I want to know the best way to achive that dismal, bluish effect you see so much in the movies. Should I use a filtered lens, or do it in post? The movie that comes to mind is Seven. I'll be using a PAN. ag-hvx100b. Thanks in adavance!!!!!
sray.
  • 20073 posts
Posted 29 July 2006 - 08:48 PM
sray.
"Seven" is not a particularly blue-ish movie to me -- sort of brownish, actually.
You can cool off the image any number of ways: white balance trick, using the wrong color temp preset (I'm talking about video cameras), blue-ish filters, blue-ish lighting, timing the image in post bluer, using tungsten-balanced film stock in daylight conditions with no or only partial filter correction.
So on your DVX100B, the fastest trick would be to just flip to the 3200K (tungsten) white balance preset when shooting under 5500K (daylight) illumination. If that's too blue, you could instead white balance to a warm (orange-ish) card or to a white card with a warming filter on the lens. Or use normal white balance or normal preset color and add a cooling (bluer) filter to the lens. Or shoot normal and make it bluer in post timing.
#3 sray
sray
  • 4 posts
Posted 29 July 2006 - 09:18 PM
Thank you sooo much!!!!
#4 Andrew Roddewig
Andrew Roddewig
  • 21 posts
  • Electrician
Posted 29 July 2006 - 11:53 PM
Now, I have yet to use the DVX 100B, but in the A there is a menu option for Color temp ( i think that is what it is called in the menu, but i am not certain.) it allows an adjustment of either more blue or more orange to about twelve i beleive. I often use that setting on a shot by shot basis to make minor adjustment to the overall color of the Image. I find their is a big jump between 4 and 5, and -4 and -5.
#5 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 30 July 2006 - 08:30 AM
HMI lighting can both be full spectrum yet still give the picture a very slight bluish look, is that what you are talking about?
#6 Chris Keth
Posted 30 July 2006 - 10:26 AM
The DVX actually has a nice graduated way to alter the color balance. In one of the menus, there's a "color temp." setting. Turning the number up will make the image go bluer, going lower will make the image go warmer. I would white balance correctly and just use that to adjust the color to your liking. It'll be easier to get it just right that way.
#7 G McMahon
G McMahon
  • 161 posts
Posted 30 July 2006 - 11:57 AM
Cheap way. If you have a filter swatch book,white balance through colours of the opposite side of the colour wheel (try colours around orange). Even be novel and try obscure colours, you may get a result you like as opposed to blue. Unfortunately, the director will see what you like on the monitor and definitely not like it, unless they have seen it in a feature film they like.
I don?t mean to insult you. Line up camera with white reference material under the lighting you will be using. Hold colour swatch directly in front of lens (helps to zoom in). And press the white balance. Some Gels may be too dark to register. It is certainly a lot cheaper than a colour grade.
Graeme
#8 Chris Keth
Posted 30 July 2006 - 07:00 PM
Which shows why it isn't a color grade and shouldn't be a substitute for one. :P
Edited by Christopher D. Keth, 30 July 2006 - 07:01 PM.
