Chungking Express
9 replies to this topic
#1 Patrick McGowan
Patrick McGowan
  • 173 posts
  • P.A.
  • Brooklyn, NY
Posted 02 August 2006 - 04:47 PM
I just watched Chungking Express and I was really impressed by how beautiful and engaging it was, plus I really love Faye Wong. In a few sequences there was an exaggerated motion blur look. I was wondering how this was achieved and if anybody has some more insights on the cinematography. (imdb simply says that it was shot in 35mm and spherical)
#2 Bryan Darling
Bryan Darling
  • 227 posts
  • Sacramento, CA
Posted 02 August 2006 - 04:54 PM
If you haven't seen any other of Wong Kar Wai's films, might I recommend the following:
-Fallen Angels
-Happy Together
-In The Mood for Love
-2046
There are others but these I highly recommend, and not just for excellent photography.
#3 Jason Debus
Jason Debus
  • 311 posts
Posted 02 August 2006 - 05:40 PM
These were filmed at a slower frame rate then printed so that the speed is correct when run at 24 fps. I'm not sure the exact frame rate they used (I think the sequences weren't all the same), but for example if they filmed at 12 fps then they would print 2 frames so that the motion was correct when run at 24 fps. They may have opened up the shutter more than 180 as well to get that dreamy motion blur.
#4 David Mullen ASC
Posted 02 August 2006 - 08:00 PM
The shutter was 180 degrees, but the frame rate was 6 or 8 fps, then each frame was reprinted 4 or 3 times to get back to 24 in an optical printer. At 6 fps with a 180 degree shutter, the shutter speed is 1/12th of a second, hence all the motion blur.
The movie was shot on Agfa stock, XT320 probably. "Fallen Angels" was shot on Fuji 250T stock mostly, with a lot of push-processing.
#5 Jozo Zovko
Jozo Zovko
  • 9 posts
  • Venice, CA
Posted 15 August 2006 - 10:50 PM
DAVID wrote >>>
In reply -
There "may be" one scene where they did open the shutter past 180* - if you look at the scene where the power goes out and the store is lit with candles - you will see all sorts of vertical streaks running up the frame on all of the highlights and candle flames - my only guess would be that they shot the scene with a MovieCam compact (who can open up past 180* - though not marked that way) or maybe shot with an Eclair CM3 (some models can go as far as 220* i think - correct me if the numbers are off) Doing so would have only added 1/4 of a stop - but at those low light levels - every bit of stop helps
But the smears that were mentioned before were of course due to the longer exposures during the scenes shot off speed and step printed - as David pointed out
Adios - have a good day
Joe Zovko
AC
LA, CA
#6 mailsb
mailsb
Posted 15 August 2006 - 11:09 PM
if you can think of cause of blurr,i mean why and how a image gets blurred in still photography,same principle apply in motion picture photography,its all to do with shutter time and frame rates.
if you still wont figure out then i will write you in detail. :ph34r:
#7 David Mullen ASC
Posted 16 August 2006 - 12:34 AM
A longer-than-180 degree shutter (like 200 or 220 degrees, which a few cameras can do) would not cause the streaks unless it was open so long that the film started advancing to the next frame before the shutter closed. The streaks are usually caused by a shutter timing error.
#8 Ignacio Aguilar
Ignacio Aguilar
  • 410 posts
  • Madrid, Spain
Posted 13 August 2011 - 07:19 PM
The look of the push-processed low-con stock on this film is wonderful. Anyone knows which lenses were used? They seem to be uncoated since there's a lot of halating, but in a nice and organic way.
The look itself of this picture reminded me of "Infernal Affairs" (remade by Scorsese as "The Departed") with all those uncorrected fluorescent tubes. At first I thought that "Chungking Express" was all Christopher Doyle, but Andrew Lau is credited as co-cinematographer, which makes sense as he co-directed and co-photographed "Infernal Affairs" as well.
#9 Brian Hulnick
Brian Hulnick
  • 358 posts
  • Sound Department
Posted 29 September 2011 - 01:20 AM
Chungking Express, a great movie and a great looking movie.
Edited by Brian Hulnick, 29 September 2011 - 01:20 AM.
#10 Mael Robijns
Mael Robijns
  • 10 posts
Posted 23 June 2014 - 03:52 PM
Does anybody know which lenses they used?
And which focal lengths? To my eye seems most of the time a normal to wide-ish focal length.
