Manual for the KINOR-16 CX-2M
#1 Tomas Stacewicz
Tomas Stacewicz
  • 50 posts
  • Gothenburg, Sweden
Posted 06 August 2006 - 04:00 PM
Does anyone know where I can find a manual for the KINOR-16 CX-2M in English?
I've done a search for one on the internet but yet haven't found any.
Are there any online manuals, or must I buy a printed one?
#2 Tomas Stacewicz
Tomas Stacewicz
  • 50 posts
Posted 20 August 2006 - 04:16 PM
Anyone?
1. Where can I find a manual for the Kinor-16 CX-2M?
And also:
2. What is the shutterspeed for the fixed filmspeed of 25 fps?
3. What about loading the 100' magazines? I only have previous experience of loading daylight spools with my Krasnogorsk 3. Well, the daylight spool obviously doesn't fit into the magazine of my Kinor-16. But there are splastic non-daylight spools (without the covering) just for fastening and winding of the film. Can I buy 100' loads from Kodak already winded on these spools? Are they international standard? Or am I forced to wind the spools myself? If so, how do I wind the film to the spools thight and even when the sides (as in the daylights spools) are missing? Any suggestions? How do YOU do it?
Best regards,
Tomas
#3 andres victorero
andres victorero
  • 412 posts
  • Spain
Posted 20 August 2006 - 05:50 PM
I don´t know about kinors, but Olex is a great guy that can give you the info that you need.
This is the olex kinor web page:
http://www.geocities...nor-16sx-2m.htm
#4 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 21 August 2006 - 01:33 AM
Anyone?
And also:
Best regards,
Tomas
I have not english version of user manual of Kinor-16 camera, but, if you will have questions, you can ask me.
If you need russian user manual, i can give copy.
The many information about use of Kinor-16 camera you can see on my pages :
- technical information http://www.geocities...nor-16sx-2m.htm
pages about prime lenses, zoom lenses, film magazines, procedure of loading film into 30 m, 120 m film magazines.
The information about repair of Kinor cameras :
http://www.geocities...ep-kinor-16.htm
The information about modification of Kinor cameras :
http://www.geocities...kinor-motor.htm
2. Kinor-16-SX-2M have one blade shutter disk ( mirror disk ) with 170 degree of angle ( shutter open ).
The time of frame exposing with speed 25 fps 1/53 sec, 24 fps 1/51 sec.
3.16 mm film can be on 100 ft daylight spools and on plastic core.
The 30 m film magazine of Kinor-16 camera compatible with film on 100 ft daylight spools and on core.
The 120 m film magazine can use with 120 m roll of film on core only.
The 30 m film magazine of Kinor-16 camera have removable part on takeup and feed axis.
If you take away removable part, you can set film on 100 ft daylight spool.
This is removable parts use for load film on core.
From my personal experience, i recommend use core on takeup axis only.
The 100 ft daylight spools on takeup axis work with not confidence too much and film can have jam.
The Kodak metal 100 ft daylight spools can work good, but, the problem with jam of film can be too. need test of every magazine with daylight spools.
If you wish use of 16 mm film on daylight spools, you can load film on spool into film magazine on feed axis and set core on takeup axis. The film on core take any processing lab for processing.
Yes, of course, You can loading of film into film magazine with daylight, but, unload of film magazine, you need do on darkness or inside charging bag only.
#5 Tomas Stacewicz
Tomas Stacewicz
  • 50 posts
Posted 21 August 2006 - 11:50 AM
Thank's again Olex for your valuabe support!
Yes, thank you! You can send it to: tomas.dahlheim@comhem.se
O.k. I tried this a second time and it worked! :)
Thank's for the tip!
Edited by Tomas Stacewicz, 21 August 2006 - 11:53 AM.
#6 Hans Engstrom
Hans Engstrom
  • 195 posts
  • Sweden
Posted 21 August 2006 - 11:54 PM
Take contact with Anders Banke. He´s the director of "Frostbiten" and you can talk swedish with him. http://www.solidentertainment.se/
