Matching 2 SDX 900's
#1 Craig Needelman
Craig Needelman
  • 11 posts
  • Philadelphia, PA
Posted 08 August 2006 - 02:46 PM
I thought I could match 2 SDX900's by taking my SD card out and reading the same file onto the rental camera. Both cameras were in preset, same setting on filter wheel. Skin tone did not match. I then white balanced each camera and everything was perfect. Shouldn't they have matched in the preset mode?
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 08 August 2006 - 03:34 PM
Preset is just a white balance made at the factory & can be changed by somebody fiddling!
Stephen
#3 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 08 August 2006 - 05:09 PM
With a vectorscope it would be easy enough to adjust the two cameras to match in preset mode. As stated, a preset can be, well, reset.
#4 John Ealer
John Ealer
  • 187 posts
Posted 09 August 2006 - 08:15 AM
In an ideal world, the two cameras with the same settings (and same lenses), would match.
But even with matched settings, variances emerge due to age, use, etc. in lenses, sensors, prisms, and, filter wheel filters, you'll generally need to do some sort of color adjustment to make them match, which means either white balancing, or using a waveform vectorscope.
This isn't a trait unique to any particular camera.
J
