Converting lamps to 230v
#1 Gav O Reilly
Gav O Reilly
  • 11 posts
Posted 09 August 2006 - 05:13 AM
Can anybody advise me on the possibillity of adapting 120 volt lamps to 240 to use in Europe?
#2 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 09 August 2006 - 06:47 AM
What a 120 v lamps you wish adapting ?
If you tell about halogen lighters, you need replace of 120v lamps on 240 v version with similar sockets.
You will need think about other type of power connectors too.
Other idea, use AC240-120 v transformers. But, the high power transformers have big weight.
Other idea, use petrol generator with 120 v outpit. This type of generators can be problen in Europe.
Possible, you need rent of lighters in Europe.
You not need forger, the main power 120 v have frequency 60 hz, 240v have 50 Hz, that's why need this about speed of shooting too.
#3 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 09 August 2006 - 12:12 PM
One possibility is running two equal wattage 120 volt tungsten lamps in series on the 240 volt line. A certified electrician should do the wiring.
You cannot run two lamps of different wattage in series, as the lower wattage one will be overdriven.
#4 Chriss Kostabill
Chriss Kostabill
  • 8 posts
  • Thessaloniki, Greece.
Posted 10 August 2006 - 01:30 PM
You can also use dimmers for the job like this one. You can trim the volts to exactly 110v-120v and keep it in that position with a duck tape!
#5 Brian Drysdale
  • 5193 posts
Posted 10 August 2006 - 02:56 PM
If you're using film lights why not just buy the 240v bulbs for the lights. Seems a lot less messy and could work out cheaper in the end.
