Mysterium Sensor to be 4900x2580
15 replies to this topic
#1 Jim Murdoch
Jim Murdoch
Posted 10 August 2006 - 07:53 AM
I actually saw this over at CML where Greg Lowry posted a quote from Jim Jannard that was apparently originally posted on www.dvxusers.com. (Whew!!)
Trouble is, the only dvxusers.com site I can find doesn't seem to have anything to do with cinematography!
If it's true, RED are claiming that the mysterium sensor will have 4900x2580 pixels, of which only 4520x2540 will be available for output, giving a standard 16 x9 aspect ratio. So that's basically a little bit smaller than the Genesis chip.
What is disturbing though is that if I read it right, it sounds like RED are only going to be showing recordings of the sensor's alleged performance, not actual live demonstrations of the camera.
"We will, unless a major castastrophy (sic) happens, show 4k footage at IBC."
#2 David W Scott
David W Scott
  • 132 posts
  • Toronto
Posted 10 August 2006 - 10:57 AM
DVX User
#3 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 10 August 2006 - 12:18 PM
No doubt, by the time this camera is released (even if that were tomorrow), someone else will be claiming to have a 6K prototype in the works...followed by claims of an 8K, etc...and the results may still not be as aesthetically pleasing as those of a 40-year-old 35mm film camera with good glass, either in terms of resolution, or in the ability to reproduce the most organic and natural-looking flesh tones.
#4 John Holland
John Holland
  • 2273 posts
  • London England
Posted 10 August 2006 - 02:01 PM
All i can say to that is here, here , and i am in know way a ludite . john.
#5 David Mullen ASC
Posted 10 August 2006 - 03:26 PM
I'm not surprised they are showing footage, not a live image -- it's a 4K (or 4.9K) Bayered-filtered image so it has to be processed, and I suspect that the real-time processor is the next step in development, so for now, the footage they shoot has to be processed & rendered by some computer before it can be viewed. Plus it has to be scaled to whatever system they are showing it on, such as the 4K Sony projector.
#6 Thomas James
Thomas James
  • 844 posts
Posted 10 August 2006 - 11:14 PM
Yes the View Sonic 23 inch 9.2 megapixel LCD Monitor can display 3840x2400 resolutions which is close to 4k. But the monitor costs $6000 so I am waiting for the price to come down. The View Sonic only has a 400 to 1 contrast ratio.
#7 David Mullen ASC
Posted 11 August 2006 - 12:51 AM
It would be nice if you signed your posts with a real name...
#8 Jim Jannard
Jim Jannard
  • 361 posts
Posted 11 August 2006 - 01:43 AM
David is exactly right. As a reminder, we pulled the trigger on this project in Dec. 2005 (8 months ago). In that time we finalized the sensor design, began prototyping a body and system, began board designs, received the 1st sensors, built a platform to test the sensors, developed a test platform to shoot the footage we have now (last week until this Sat.) and then have to get the footage processed and ready for a projector we have never seen. I guess fast-track is an understatement.
We are either brave or foolish. We'll see at IBC. Then the real work begins.
Jim
#9 David Sweetman
David Sweetman
  • 757 posts
Posted 11 August 2006 - 02:44 AM
Sweeeet. Freakin that line itself makes me want one. Rock on. Can't wait to see what you guys come up with.
geez how would I go about editing that kind of footage...down-res to dv for the offline then get an online? I guess...what's it take to edit 4k?
Edited by David Sweetman, 11 August 2006 - 02:48 AM.
#10 Jim Jannard
Jim Jannard
  • 361 posts
Posted 11 August 2006 - 07:39 AM
There are several lower data rate options... 2K, 1080P, 720P, compression schemes, etc. But with the ability to maintain 35mm DOF.
Jim
Edited by jannard, 11 August 2006 - 07:44 AM.
#11 Arni Heimir
Arni Heimir
  • 326 posts
  • Reykjavik/Barcelona
Posted 11 August 2006 - 08:06 AM
Dear Jim
What will he bit rate per second be for 4.5k? Will you use Jpeg 2000 compression or be developing your own? Will the recorder be dockable like the Genesis or more in the realm of the D-20?
Árni Heimir
#12 Phil Rhodes
  • 12167 posts
Posted 11 August 2006 - 08:31 AM
JPEG2000 would be a reasonably smart move.
Phil
Also:
10-bit 4K RGB, that is 4096x3120, works out at just over 1Gbyte/sec plus framing overheads. That said, to store the raw data off a bayer sensor such as the one we're discussing is a slightly more feasible 330-odd megs a second. This is quite achievable with a disk array that would be at least somewhat portable and ought to render down to extremely decent 4:4:4 2K.
Anyone attempting to post 4K off this camera is giving themselves a rather unnecessary headache.
I had hoped that a camera like this would have enough ASIC on board to allow debayered dual-link HD-SDI output up to 2K. Not doing so vastly reduces the number of recorder options, but then they might be banking on those as the moneymaker. This could of course kill the project stone dead - Viper existed for years before it was usable because of the recorder situation.
Phil
#13 Thomas James
Thomas James
  • 844 posts
Posted 11 August 2006 - 10:40 AM
I would like to see the camera come with 4 1080p60 encoding chips with 4 firewire outputs so that I could record the 4k signal to 4 HD-DVD decks. Then I could hook up my HD-DVD decks to my View Sonic 23 inch monitor that has 4 DVI inputs. I prefer firewire over HD-SDI because HD-SDI sounds like it is more expensive to support. What I would like to see is an affordable solution like Quad HDV.
#14 Jim Jannard
Jim Jannard
  • 361 posts
Posted 11 August 2006 - 11:58 AM
We recognize that we need to provide solutions from the highest end (RAW 4.5K) down to 30Mbs recorded on board. We have our hands full. But we knew that going in.
Jim
#15 Keith Mottram
Keith Mottram
  • 824 posts
Posted 11 August 2006 - 12:42 PM
this is nonsense, which is why i assume you only post under androbot, in fact maybe i am addressing a computer programme that randomly spits out technical words. seriously though why bother with this, why not suggest hooking it up to a series of cucumbers, as that would be both affordable and for a few extra pennies organic too boot.
all the best,
technotwat75
#16 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 11 August 2006 - 02:48 PM
You won't get much more than 400 to 1 from any monitor. Some companies measure the black with the screen turned off to make the numbers sound better.
Stephen
