A-minima 200ft loads
#1 Allyn Laing
Allyn Laing
Posted 11 August 2006 - 03:54 AM
Hello,
I am shooting with an A-minima next week, I am planning to use 2 different fuji stocks for a particular aesthetic of the piece. Is it possible to wind my own rolls onto empty 200ft Kodak cores from Fuji 400' rolls? If so what are the specific requirements?
Any help will be of great assistance.
Allyn
Student DP
Melbourne
Australia
#2 daniel mahlknecht
daniel mahlknecht
  • 190 posts
  • Italy - South Tyrol
Posted 11 August 2006 - 07:07 AM
I have heard, that it has been done, of course it must be done in total darkness.
Also it is important to consider that the AATON minima requires that the film is with the emulsion outwards (normaly the other way round).
Also it will not work with normal 200ft daylightcores, as the minima needs the specially designed plasticcores, but if you have some.
An other problem could be, that being wound the otherway round (emulsion ouswards) the film has another tension (I hope you understand this, as my english is a bit so so), so if you use film that previously had been on a core emulsion inside, once put it on a minima core it will tend to curve (like a spring) the otherway round. Now in the minima the tension of the film while running through the gate has been calculaten when collimating the flange focus distance. I will change the flange focus only minimally, but I'v been told that it could cause focus poblems.
maybe this problem could be resolved by loading the core at least a week before shooting.
I have loaded 400ft rolls on 100ft rolls for my bolex in the darktent, there you have to spool twice in order to get the perforation on the right side, I don't know if this is thru also for the minima, might be not as emulsion is outwards, but you will have to try.
I hope this was of help
daniel
#3 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 11 August 2006 - 12:43 PM
Hello,
Allyn
Student DP
Melbourne
Australia
As I noted in your cross-posting, since you likely could use one of the many Kodak stocks available in 200-foot A-Minima loads to emulate the "aesthetic" you are looking for, it probably is not worth the effort and risk of "loading your own". Rewinding and winding camera film in total darkness requires great care to get uniform tension and an even wind, and to avoid issue like static marks and handling marks. Of course you must wind to get the proper orientation of emulsion-out and A-wind with the KEYKODE or MRCode reading in the correct direction.
#4 John Adolfi
John Adolfi
  • 342 posts
  • Fulton, N.Y.
Posted 11 August 2006 - 04:20 PM
What again are the A-Minima Kodak films that can be used?
#5 Adam Frisch FSF
Adam Frisch FSF
  • 2027 posts
  • Los Angeles, USA
Posted 12 August 2006 - 06:23 AM
Yes, I have done it. Most labs have a darkroom with spooling facilities, so it shouldn't be a problem.
Unfortunately, as I recall it, you have to spool it twice from 400ft roll: first to get the perfs down (or up, depending on which way you spool), then to get the emulsion side out. Most labs have empty A-minima cores they can give you.
#6 Allyn Laing
Allyn Laing
Posted 12 August 2006 - 11:39 PM
Have you ever had focus drift problems because of the 'bend' being the opposite way?
#7 Allyn Laing
Allyn Laing
Posted 13 August 2006 - 10:46 AM
Have you ever done any timelapse on the camera before?
Allyn
#8 Mark Lyon
Mark Lyon
  • 66 posts
  • Solana Beach, CA
Posted 13 August 2006 - 08:48 PM
Allyn
Hi Allyn--
I own an a-minima, have shot a ton of timelapse on it, and shot re-spooled film too. I didn't have any trouble with the re-spooled film (it was Kodak B/W reversal, though, not fuji), but for a paying job I'd definitely stay with the factory-spooled kodak film.
I also have some empty A-minima spools, but I'm in California--hopefully you can find a source in Oz.
What's your timelapse question?
Take care,
Mark Lyon
Mighty Max Films
#9 Will Paguntalan
Will Paguntalan
  • 7 posts
  • Hollywood ,Ca.
Posted 13 August 2006 - 11:07 PM
Hello,
Allyn
Student DP
Melbourne
Australia
If you do spool down make sure you turn those reels SLOWLY as I ruined 400ft by winding fast and
"sparking" all the footage (static sparks from friction)
That was a long tima ago -and I havent forgotten!
GOOD LUCK
