Cheapest 16mm pin registration cameras
10 replies to this topic
#1 John Adolfi
John Adolfi
  • 342 posts
  • Fulton, N.Y.
Posted 12 August 2006 - 12:00 PM
Would someone sharte with us the cheapest solutions for a pin registered 26mm camera. Also mention the need for it? Like the Canon Scoopic does not have a pin but I understand the lense is fantastic. Would not having a pin in this camera alter ones decission in purchasing a camera that could produce a great picture?
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 12 August 2006 - 12:03 PM
Mitchell pin registered 16mm cameras sell on Ebay for about $500. What doyou want to shoot?
Stephen
#3 David Mullen ASC
  • 20069 posts
Posted 12 August 2006 - 12:11 PM
The Scoopic has a permanently mounted cheap zoom lens on it -- I doubt it is very good but it may be adequate for what you want. The Scoopic is really a consumer Super-8 camera on steroids.
Most 16mm cameras use the pulldown claw to help register the film, especially since Super-16 only has perfs on one side. The image is usually pretty steady on cameras like the Aaton despite the lack of a registration pin due to the pressure plate, etc.
You'd have to use an old Mitchell probably, and it probably can only run regular double-perf 16mm stock if the pin is on the opposite side of the frame than the pulldown claw. Are you doing effects compositing work, is that why you need a pin-registered camera?
#4 shutter bug
shutter bug
Posted 12 August 2006 - 12:22 PM
although im not a fan of the scoopic in any way,i have to say the lens isnt cheap if its at all similar to the ds8 version. the ds8 zoom has something like 7 rare earth elements in the optical design. granted its only a single coated lens and an older design but it does put out rather good pictures. if the 16mm scoopic has a similar design then id expect to see good quality images out of it.ive even met a cinematogpher who used one a few years ago to get some shots on horseback due to its size, and they were quite happy with the results.i still sure as hell wouldnt get one.
#5 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 12 August 2006 - 12:35 PM
---I have used the Calarts Scoopic back when. The lens was better than an Angie 12-120mm.
Contrastier. Very snappy looking image.
---LV
#6 Max Lundberg
Max Lundberg
  • 28 posts
  • Europe
Posted 12 August 2006 - 01:00 PM
There are a couple different models of Scoopic. The lenses are not the same and some of them have a registration pin(like relatively rare "Sound Scoopic").
#7 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 12 August 2006 - 01:45 PM
Kinor-16 SX-2M.
16 mm PRO cine camera, reflex system, pin registrated, 30 m, 120 m film magazines,
electrical motor with systemof stabilizatin of speed.
You can see many letters about Kinor-16 on old topics.
If you need more details, and have questions, send me letter on e-mail
olex@a-teleport.com
#8 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 12 August 2006 - 02:25 PM
Arriflex 16S. Pin registration, built like a tank, the S/B can take any of the Arri Bayonet mount lenses, sync motor available, 1960's professional MOS 16mm camera, can be had on eBay from $700 to $1200.
-Tim
#9 Mike Rizos
Mike Rizos
  • 330 posts
Posted 12 August 2006 - 09:58 PM
The early grey Scoopic with the 13-76 lens is the one to avoid. The 12.5-75 lens was a big improvement on later models.
#10 Rik Andino
Rik Andino
  • 783 posts
  • Electrician
  • New York City
Posted 13 August 2006 - 01:21 AM
I don't really know if they make 26mm cameras... :)
Sounds like a phony format to me.
Seriously though with the quick edit option on you can quickly check your mistakes
& then go back to fix them. It doesn't take that much effort.
Would not having a pin in the camera alter ones decission in purchasing a camera
Are you're asking us questions for a survey on pin-registered cams?
Cause that's what this sounds like.
Tell us you're problem or situation and you're specific needs
So we can better answer your question.
#11 Will Paguntalan
Will Paguntalan
  • 7 posts
  • Hollywood ,Ca.
Posted 13 August 2006 - 11:19 PM
As an owner of one Scoopic I and 2 "M"s :the lens on the M is quite nice . sharp, warm and contrasty
Unlike the "I" that was just bad.
Shot a fair amount of 2nd unit -matching ARRI SR2 footage rather perfectly -IMHO
I only wish I could afford to re-barrel the lens and mount it on my CP-GSMO!!
(oh yeah and that canon 1.5x extender is a magnificent piece of glass!)
