How much volt to run camera at 54fps
#1 Hans Engstrom
Hans Engstrom
  • 195 posts
  • Sweden
Posted 12 August 2006 - 07:35 PM
How much voltage does it take to get the LTR54 to do 54fps. I know 16V is good but can i do it with less like 14.4V? How much volt can the camera take, I guess a 16.8V battery would be ok, or not? Why I´m asking is because I´m planning to adapt some powertool batteries to my Aaton as that would be a much cheaper solution than using the original onboardbatteries. I have allready built myself lead acid blockbatteries and they work great but it would be nice to have some onboards that can get the camera running at 54fps.
#2 Steve Phillipps
Steve Phillipps
  • 28 posts
Posted 14 August 2006 - 04:26 PM
As far as I know it'll got to 54fps with 12V, it's only when going to 72fps that it needs 16V. My 16V batteries often read 17+ volts on my XTR Plus display.
#3 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 14 August 2006 - 10:12 PM
The LTR can go up to 32fps on 12v. You can use a 14.4v battery to get to 54fps, but it will need to have a fresh full charge, which means that it will be somewhere in the 16v range. My 16v batts top off over 18v coming off the charger.
#4 Hans Engstrom
Hans Engstrom
  • 195 posts
  • Sweden
Posted 15 August 2006 - 05:19 PM
Thanks, time to go shopping for batteries.
