Sony DXC537 - Highlight flare / Edge tear
#1 Michael McIntyre
Michael McIntyre
  • 96 posts
  • Denver, Colorado
Posted 13 August 2006 - 05:17 AM
DXC 537 showing flaring end edge tears on bright objects (see attached). Highlights / edges flare to the right. Stills don't do it service as they literally dance along edges during playback.
Issue will be addressed by a tech soon. I just thought I'd ask if anyone has seen this on older cameras and if I might be over-worrying about capacitors getting weird. I realize it could be the record heads too (older PVV-1A) but it's so light-specific that I can't be sure.
Beyond this simple yard test, I have re-tested with varying tape stock, playback decks and lighting. Soft, flat light and everything sings. Colors pop like it was a newer head. The deck has the occassional dropout / hit to be expected from its age.
Add one hot spot or hard, contrasty edge and it just rips to the right with little lines zipping along. Take a look and let me know if you've seen or had to have this repaired. This will be handled by a Sony tech and I wanted to have a better idea before handing it off.
I'd like to see more life out of this camera so I'm doing some research. Plenty more frame-grabs if these aren't clear or representative enough. Thanks.....
Any and all input appreciated..... Blade_Hi_Light.jpg Doghouse4web.jpg Trees4web.jpg ent]Beam4web.jpg
#2 W Keith McManus
W Keith McManus
  • 2 posts
  • Philadelphia, Pa. - U.S.A.
Posted 14 August 2006 - 08:27 AM
Any and all input appreciated..... Blade_Hi_Light.jpg Doghouse4web.jpg Trees4web.jpg Beam4web.jpg
Its not the camera, its your record deck that is the problem.
#3 Michael McIntyre
Michael McIntyre
  • 96 posts
  • Denver, Colorado
Posted 14 August 2006 - 02:22 PM
Thanks, Keith, for the response. I think you're right. I did some digging around after posting that and have seen similar problems elsewhere.
I'll take it in. Anyone else have the same issues? I think we're looking beyond the old head cleaning (obviously). Ideally, the drum's okay.
#4 Michael McIntyre
Michael McIntyre
  • 96 posts
  • Denver, Colorado
Posted 16 August 2006 - 05:57 AM
Rather than capacitor issues, most likely tape-transport / tension / pinch rollers or any combination therein. Worst case is the heads.
My description of "highlights / edge tears" is what's referred to as 'bearding'. Nothing too revelatory in this post I realize.
To that end - anyone got any PVV-1A heads / drums lying around? Thanks as always......
