Kinor vs. Arri
#1 Kelley Cross
Kelley Cross
  • 11 posts
Posted 14 August 2006 - 01:57 PM
I'm curious as to whether anyone has shot with both an arri bl-4 and a kinor (35 h or c) and could describe some differences. I just purchased a kinor and plan to do two projects in September. I've tested about 1,000 ft. so far and the registration seems rather solid. The projected prints are nice. My limited experience with the arri was nothing but great. An excellent camera and obviously very quiet. There is a fair amount of noise from the Russian camera in comparison but for shooting exteriors, it doesn't seem to be an issue. The lomo lenses are comparable to the Zeiss in terms of sharpness, in my opinion. I would love to get some other thoughts.
Kelley Cross
#2 Adam Frisch FSF
Adam Frisch FSF
  • 2027 posts
  • Los Angeles, USA
Posted 15 August 2006 - 05:37 AM
The Kinors can be alright. I shot with them quite a bit when I was starting out and had mixed experiences. Generally, I'd say that russian mechanics are normally fine - crude, oversized but long-lasting. The electronics are however the weak spot. Thankfully, you can upgrade the electronics on the Kinors - I have a contact for you if you'd want to do that.
I trekked with one in a backpack to a lot of high peaks in Wales under very adverse conditions and had no problems whatsoever. But one another shoot, uncharacteristically, the main shaft on the Mitchell-type movement seized up on me. This took a long time to rectify, but we managed in the end. That shaft should really be in a ball bearing. So, just like Panavisions, you have to lubricate the movement at certain intervals, or it might not perform properly.
They're also virtually impossible to convert to PL-mount due to the FF and design of the mirror, so If this is your aim then I'd suggest another camera.
#3 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 15 August 2006 - 06:53 AM
PV's & Mitchells require lubricating once a day @ 24 fps.
Stephen
#4 Kelley Cross
Kelley Cross
  • 11 posts
Posted 16 August 2006 - 06:01 PM
That sounds interesting Adam. What sort of contract? Do you do the conversions?
#5 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 17 August 2006 - 04:19 AM
Try member Anders Banke, I know he has done electronic upgrades & owns a selection of 2 Perf cameras.
Stephen
#6 Adam Frisch FSF
Adam Frisch FSF
  • 2027 posts
  • Los Angeles, USA
Posted 17 August 2006 - 11:30 AM
Stephen
That's the guy. Nobody has better connections in Russia than him since he speaks it fluently and owns enormous amounts of Russian gear.
They developed a new circuit board for the Kinors that is a major improvement. Incidentally, the same guys make an improved circuit board for the Arri BL range that's much cheaper than the P+S Technik stuff also.
He can be reached through the website www.solidentertainment.se
#7 Kevin Masuda
Kevin Masuda
  • 209 posts
Posted 17 August 2006 - 09:58 PM
Bruce McNaughton over at The Aranda Group in Australia does updated electronics for Kinors and Konvases for a relatively low price. I just got my Konvas updated and he does excellent work. Check out their website. www. arandafilm.com.au
Kev
#8 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 18 August 2006 - 01:36 AM
About update of Konvas, Kinor-16 and motors of other cameras, can ask me too.
I can modify 17EP-16 APK, 18EP-16 APK, 15EPSS, 19EP-16 APK , 29EPSS, 10EP-16 APK motors and motors of other cine cameras on crystal sync multi speed motors with microprocessor controller.
#9 Bruce Taylor
Bruce Taylor
  • 482 posts
Posted 20 August 2006 - 11:50 PM
Yes, Bruce over at Arandafilm has a new 5000 speed motor mod for the Kinor (and Konvas) that looks sweet (and reasonable). Also, I was in contact with Steve Morton (also in Australia), he said he is coming up with a motor mod too. Looks like he has other nice Kinor mods as well- you might check out his page at:
http://members.optus...cinecamods/mods
