good telephoto?
#1 Landis Tanaka
Landis Tanaka
  • 54 posts
Posted 15 August 2006 - 01:36 AM
I need something that can go to around 120mm or 150mm
any thoughts?
#2 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 15 August 2006 - 07:57 AM
any thoughts?
You looking for a zoom or a fixed focal length lens? If you want a zoom, the Angenieux 12-120 goes up that far. They also make a 10-150 I believe. The quality of the Angenieux's can range pretty much all over the map, so it would be best to do a test before you buy or rent. I have a 12-120 that makes beautiful images, and I have seen ones just like it that make soft images. So it depends alot on the individual lens.
If you end up buying an Angenieux, I highly recommend Paul Duclos of Duclos Lenses for service. He will get the very best out of any Angenieux lens.
-Tim
#3 Dan Horstman
Dan Horstman
  • 94 posts
  • Washington, DC
Posted 15 August 2006 - 12:59 PM
any thoughts?
Is your K3 an M42 Screw mount or bayo version?
If it is M42 - look for M42 still lenses on Ebay.
#4 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 15 August 2006 - 02:55 PM
any thoughts?
If you have K-3 with M42 screw mount :
Jupiter-11 135 mm/f 4.5 M42 ( not mix with version for rangefinder cameras )
Jupiter-21 135 mm /f4.0 M42
Tair -11 135 / f2.8 ( can have M39 version, need set screw ring M39-M42)
Zeiss Sonnar 135/F3.5 M 42 ( Pentax, Pracktica )
Tair-3 from photo snipper 300 mm F4.5
The lenses from medium format cameras Pentacon siz, Kiev-66 with adapter
P6-M42
Vega -28 120 mm f2.8
Kaleynar-3 150 mm f2.8
Zeiss Sonnar 180 mm f2.8
Jupiter-36 250 mm f3.5
