Cineframe Downconvert
#1 Rudi Siira
Rudi Siira
  • 1 posts
  • Melbourne, Australia
Posted 15 August 2006 - 05:08 AM
Just wondering if anyone has shot HDV with Cineframe25 then downconverted over firewire into DV. Can this produce progressive SD images or should I downconvert in post?
#2 Matt Sandstrom
Matt Sandstrom
  • 464 posts
  • Stockholm, Sweden
Posted 17 August 2006 - 10:03 AM
interesting question. shooting sd with cineframe25 does indeed produce true progressive images with this camera. shooting hd and downconverting will most likely produce a slightly softer result since the image will be processed twice, while it will obviously still be progressive. please let us know if you shoot a test. i haven't and i don't have access to this camera right now.
/matt
#3 Thomas Tamura
Thomas Tamura
  • 33 posts
  • Denver Colorado
Posted 05 September 2006 - 02:33 AM
A little off topic, a little on,
I recently photographed a music video in SD using the cineframe30 -- I shot some tests and liked the motion rendering much better then the cine25. viewing the captured image I did feel it was a bit softer then what I was seeing on set. I'm assuming it's the in-camera SD processing, and since it's down converting an HD image I would assume that down converting during capture would render the same results. I am very happy with the shoot - if the editor had the capability to down convert I would have preferred to shoot HD, but a job's a job.
I would assume the cineframe30 is interlaced, but not sure?
