goodman's gide for PAL
#1 Mario van Zijst
Mario van Zijst
Posted 15 August 2006 - 09:31 AM
Does anybody knows if there is an goodman's gide for the 900 in the PAL version?????
thanks
#2 Pino Brambilla
Pino Brambilla
  • 2 posts
  • Italy
Posted 16 August 2006 - 05:14 AM
thanks
Yes, I had one from my dealer when I purchased my SDX900E. I trust the Guide is the same for NTSC and PAL, the only difference is the mini CD disk attached to the book, which contains PAL scene files.
Pino. Audio Visual Studio
#3 Sacha Seibert
Sacha Seibert
  • 1 posts
Posted 18 August 2006 - 04:41 AM
Hi Pino, do you still have this PAL-Scene-Files?
I would be very interested. Maybe you can attache some in a post...
Thanks for your answer.
#4 Pino Brambilla
Pino Brambilla
  • 2 posts
  • Italy
Posted 19 August 2006 - 06:06 AM
Hi Sacha, I'll try to send you the PAL set-up files folder. If you have problems, send me an e-mail directly to my address: pino@audiovisualstudio.it. The numbers in the text files are exadecimal values, but it is easy to convert them in decimal values to manually set the camera's menu.
I found the values for H and V detail too low, the images appear very flou with that values ( 3 and 2 respectively). I don't use a HD lens, but a broadcast Angenieux one.
I normally set them to 10 and 8. or 14 and 10. The factory values by Panasonic for the sdx900e are too high, and the contours are too much enanced. I would like to know if somebody has experienced a good detail set-up for PAL video, to use in conjunction with a good video brosdcast lens, but not HD quality.
Best regards.
Pino
