Canon XL H1 4-channel audio
#1 Albert Koval
Albert Koval
Posted 15 August 2006 - 01:55 PM
By now we've all learned that capturing HDV channels 3&4 from the XL H1 into FCP is not an easy task.
Since the audio stream is 392kbs regardless of whether the audio is recorded as 2-channel stereo (196kbs x2) or 4-channel (96kbs x4), it seems that if there was a way to access the greyed-out options for audio capture in the HD capture presets, FCP *should* be able to decode the audio stream correctly.
Any thoughts out there?
#2 Albert Koval
Albert Koval
Posted 16 August 2006 - 01:40 PM
Oops, I didn't get those data rate numbers quite right did I? :-(
The Canon XL H1 HDV audio stream is 384kbps, the stereo stream is 192kbps x2, and the 4-channel stream is 96kbps x4.
--Albert
#3 Mr. Shannon W. Rawls
  • 127 posts
  • Lemiert Park(Hollywood), CA.
Posted 21 August 2006 - 11:52 AM
Al,
Check this out: http://www.xlcinema....read.php?t=1084
#4 Albert Koval
Albert Koval
Posted 01 September 2006 - 02:09 PM
Thanks Shannon. It's good to know I'm not the only one experiencing these problems. I solved my current problem for this particular project by recapturing the Audio/Video streams and recombining the audio and video tracks, but it was a lot of extra work.
I am going to persevere on this issue to see if we can't get the custom HD capture presets in FCP to allow selection of all 4 audio streams...
--Albert
Al,
