Getting Correct Color Temperature Out of Lights
#1 Drew Hoffman
Drew Hoffman
  • 57 posts
  • Chicago, IL
Posted 16 August 2006 - 11:07 PM
With CTO; CTB; CTS; + Green; - Green all in a variety of increments... are there any tricks for making sure that you're using the right gels in the right combination on a particular lamp? I don't have access to a color meter and I can kind of get away using my digital camera as a guide. I'm just wondering if there are any other tricks, especially with flourescents.
Posted 16 August 2006 - 11:22 PM
Color temp meter is the only way to know for sure, other than the posted MIRED shift info for each gel. But that assumes the gel goes onto a light of known color temp.
#3 gafferdave
gafferdave
Posted 17 August 2006 - 06:02 AM
'I'm just wondering if there are any other tricks, especially with flourescents.'
Unfortunatly the colour temp of tubes changes with age so if you're on location using, say, a corridor lit by flouries then they'll be all over the place colour wise. The only way to check for sure about the colour temp of each fixture is with a colour temp meter. Alternatively you could gel them all up the same and go with the slight differences - if you think this look will be agreeable with the production's content/look etc.
Remember you can always replace flourescent tubes with balanced ones (daylight or tungsten).
