Kodak 16mm Fine Grain Microfilm 50' Roll
#1 grantsmith
grantsmith
  • 138 posts
  • 2nd Assistant Camera
Posted 18 August 2006 - 11:01 AM
Hello,
I picked up a roll of this film cheaply assuming it was some kind of tri-x b+w. It seems to be (I'm guessing) some kind of microfilm like which you get in libraries.
As it is 16mm I was hoping to use it in my camera though I don';t seem to be able to find an ASA number.
Does anyone know what the ASA is and what I'd be looking to expect if I tried it in a movie camera?
I'd also be interested in actually knowing what it is
I couldnt really find much about it on google. There dosnt seem to be a stock number either (unless 1456 is it)
GRant
#2 Dan Horstman
Dan Horstman
  • 94 posts
  • Washington, DC
Posted 18 August 2006 - 11:54 AM
As far as I know, microfilm has no perforations so it can't be shot in a 16mm camera. Wish it did though...it would be fun to play with.
#3 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 18 August 2006 - 12:53 PM
Hello,
GRant
Information about Kodak microfilm products:
http://www.kodak.com...crofilmsProduct
Many microfilms are unperforated, or don't have motion-picture perfs.
#4 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 18 August 2006 - 07:57 PM
1456 is a code for "SILVER HALIDE MICROFILM: 16mm FINE GRAIN 1456, (ESTAR base)." acording to a state contrct I Picked up from Google.
IF it is perforated try starting at ASA 10-25 and expect fairly high contrast..
If it is not in the original box, (which should have a label from Kodak or "recordak") you are probaly wasting time. The box should have the lenth, and you may find up to 215 feet on a 100 ft microfilm spool (which WILL fit a movie camera- even though it is plastic) as Microfilm can be on a thin base.
(The only time anyone ever paid me to shoot film, it was microfilm)
#5 David Venhaus
David Venhaus
  • 129 posts
  • Wiseburn, CA
Posted 19 August 2006 - 02:13 AM
Most microfilms are unperforated so you probably won't be able to use it in a MP camera but you could check to be sure. There are some other uses for it, users of sub-mini format still cameras (tiny spy cameras) sometimes like to use microfilms. I have a Kiev 303 that I shoot 16mm microfilm in, then develope it in a low contrast developer to get a more normal contrast range.
Edited by David A Venhaus, 19 August 2006 - 02:16 AM.
