Redrock M2 Adapter+DVX100b
9 replies to this topic
#1 Naaman miles
Naaman miles
  • 1 posts
Posted 19 August 2006 - 11:24 AM
Does anyone know if the M2 adapter can be used with the DVX100B?
#2 Shane Bartlett
Shane Bartlett
  • 58 posts
  • Nashville
Posted 19 August 2006 - 06:05 PM
From what I understand, yes.
I believe the M2 only threads into the 72mm filter mount.
#3 Matt Workman
Matt Workman
  • 421 posts
  • NYC
Posted 19 August 2006 - 08:47 PM
DVX100b and M2 are compatible. I've used the two before.
You can either go with the SD Achromat or the new one. There is no shimming or modding needed to fit the two together either. HVX, JVC, etc. need adjustments to fit.
Hope that helps.
Edited by Matt Workman, 19 August 2006 - 08:48 PM.
#4 Timur Civan
Timur Civan
  • 21 posts
  • New York City
Posted 02 September 2006 - 01:00 AM
Absoutly, it works on my 100a the 100b is exactly the same dimentions. However in order to "flip" the image in the LCD screen requires a special trick. On the 100 and 100a all you need is a tiny rareearth magnet next to the screen to flip the image over and make it the corrct orientation. On the 100b however, apparently there is a smal rubber panel in the hinge of the LCD screen on the 100b. Under this there is a small hole that has a pin. What exactly youre supposed to do with this i do not know. somethign about activating a small pin to make the magnet trick work. Post the question on Dvxuser . com they would know better than me. there is a solution however.
#5 Christopher Wedding
Christopher Wedding
Posted 07 September 2006 - 04:29 PM
Where does one get a rare earth magnet? I'm in LA.
Chris
#6 Timur Civan
Timur Civan
  • 21 posts
  • New York City
Posted 07 September 2006 - 05:33 PM
Chris
google it im sure somethign will pop up. you can sometimes find them in hardware stores.
Edited by Timur Civan, 07 September 2006 - 05:34 PM.
#7 Matt Workman
Matt Workman
  • 421 posts
  • NYC
Posted 07 September 2006 - 08:19 PM
I would warm against the magnet trick. You are playing with fire. Also it only flips the image one way, it doesn't really solve your problem.
Get a Varizoom SD monitor or a Xenarc. They both flip the image correctly. I have a Noga isreali arm and I just mount the monitor upside down. The new Marshalls and Pansonic monitors are easily mounted like that also.
Magnets and DVX is not a good mix. There is a reason the magnet trick is called a hack.
#8 Shane Bartlett
Shane Bartlett
  • 58 posts
  • Nashville
Posted 08 September 2006 - 09:25 PM
Indeed.
The DV Rack software will also flip your image for you both vertically and horizontally. It also gives you a waveform monitor and other goodies. Of course, the downside is keeping your laptop powered. . . .
#9 Ken Cangi
Ken Cangi
  • 155 posts
  • Boulder, CO
Posted 17 September 2006 - 10:13 PM
Chris
They are a standard item at any Woodcraft store. You can buy five or more of them for about ten dollars. This is the closest store to you: http://www.woodcraft...s...p&zip=91601
#10 Craig Bowman
Craig Bowman
  • 5 posts
Posted 02 November 2006 - 03:31 PM
DV Rack works great but I still use a Sony field monitor.
