Dimming large softboxes
#1 Jaxon Bridge
Jaxon Bridge
  • 45 posts
  • New York, NY
Posted 19 August 2006 - 01:28 PM
I recently purchased two X-Large DynaPhos softbox kits from Amvona.com. They are quite big, taking up to 2000W bulbs, with the softboxes being about 46" X 36".
If I use these in a smaller setting, I will of course need less firepower, and I'm wondering what my best options are.
The way I see it, I could use a lower wattage bulb. But would the large size of the softbox make this unreasonable? Kinda like putting 5 year-old behind the wheel of a ferrari?
Or, I could get some dimmers. But I have heard the using dimmers affects the color temperature.. anyone care to comment on how severely? Also, dimming a 1000W or 2000W bulb down to the equivalent 250W seems pretty major... would it take a particular kind of dimmer to safely and effectively accomplish this, or would any do?
Appreciate the advice,
Jaxon
  • 20072 posts
Posted 19 August 2006 - 03:00 PM
If it's a softbox with multiple bulbs, just put half of them on a different switch so you can kill 50% of the light. Combine that with a dimmer, and you should be covered. That or cut some ND gel to fit over the bottom of the box.
#3 Jaxon Bridge
Jaxon Bridge
  • 45 posts
  • New York, NY
Posted 19 August 2006 - 06:26 PM
These just have one bulb each.
Can you address the issue of dimmers' affect on color temperature? I was surprised to hear this but I haven't tested it myself.
Thanks for the advice.
#4 David Mullen ASC
  • 20072 posts
Posted 19 August 2006 - 07:21 PM
The color gets warmer the more you dim it.
You could cut some blue gels to cover to compensate, but you'd want a color temp meter if you needed to get back to 3200K exactly, to determine the right strength of blue gel. Hence why ND gel or a scrim or net may be easier.
