4ft setting when using only a 2ft kino
#1 weiming
weiming
  • 13 posts
  • 2nd Assistant Camera
  • singapore
Posted 25 August 2006 - 07:43 AM
Hi all!
Have any of u guys used a 2ft 4 bank kino with a ballast set at the 4ft function? i read from the kino manual that it is not recommended as it will cause a green spike(does green spike just mean that the light will be greener?) and increase the heat generated.
In that case, do any of u still use it at the 4ft setting and are there any things to watch out for?
thanks!
weiming.
#2 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 25 August 2006 - 02:27 PM
Yes, 'green spike' means the light output will be much greener than normal. If you want to find out how green it is, get a color meter and take a reading. But I don't think there's any good reason to use this setting unless you want the green.
#3 Kristy Tully
Kristy Tully
  • 29 posts
Posted 01 September 2006 - 03:14 PM
The 2ft and 4ft swith on the older ballasts have mostly been replaced with hi output and low output. The manual may caution you against it, but I have to say in my experience,I have never noticed more green in the light or the dailies. I was a gaffer for many years before I started shooting, and have always used the switch to get a little more light out of the unit.
#4 Paul M. Sommers
Paul M. Sommers
  • 16 posts
Posted 04 September 2006 - 02:57 PM
I haven't noticed green, but there is a definate shift towards blue.
Paul M. Sommers
