Cinematography.com - Professional Motion Picture Camera People, News and Resources
Welcome Guest ( Log In | Register )
(The ad above does not appear if you are logged in as a member. Have you registered yet? It's free!)
2 Pages V   1 2 >     StumbleUpon Digg Mixx Facebook del.icio.us TwitThis MySpace LinkedIn Sphinn Kirtsy
Reply to this topicStart new topic
Mitchell 16mm/News Reel Cameras
Christian Blas
post Aug 27 2006, 01:19 PM
Post #1
Group: Basic Members
Student
This feature I am planning to feature with 16mm and it has to do with the alternate past. I want it to seem like a documentory/TV news type of feature that has to do with a fictional war, so I decided to use newsreel cameras like the Mitchell 16mm. But questions come up when I see this camera...
Is this camera worth getting? If so, where can you locate them? I have been trying to find them but the only one I can find is a prop verson for theaterical, commerical, etc. uses. If not, then what other 16mm newsreel cameras are there to buy/rent that are worth getting?
Go to the top of the page
+Quote Post
post Aug 27 2006, 01:37 PM
Post #2
Director of Photography
Auricons were common 16mm news cameras in the 1960s and early 1970s. In the later 1970s you had the CP16 and CP16R, also Frezzolini had the FR16.
The Arri 16BL could be used for news as well.
+Quote Post
Robert Hughes
post Aug 27 2006, 02:24 PM
Post #3
Sound Dept.
IIRC the Mitchell 16mm cameras are designed for dual perf film. If you can use dual perf film then it's not a problem, but most cameras built since WW2 (including the Auricon and CP16 cameras) are single perf machines.
+Quote Post
post Aug 27 2006, 02:47 PM
Post #4
I think he's referring to the Mitchell SSR 16, which had single system sound head. Seemingly, this had a single claw and registration pin, whereas the DSR 16 double system version had a double registration pin.
+Quote Post
Christian Blas
post Aug 27 2006, 03:28 PM
Post #5
Student
So there is a rare (or no) number of Mitchells that include for single-perf registration as I see it. Is this correct?
+Quote Post
post Aug 27 2006, 03:44 PM
Post #6
Group Icon
Group: Sustaining Members
Unless you're talking about hand-cranking the camera for a Silent Era look, an old Mitchell or a modern Arri-SR3 are not going to look any different in terms of the picture they create -- what matters are the LENSES and the FILM STOCK if you're trying to emulate old footage, unless you are talking about the hand-cranked era.
+Quote Post
Charles MacDonal...
post Aug 27 2006, 04:15 PM
Post #7
Group Icon
Other
QUOTE (David Mullen ASC @ Aug 27 2006, 07:44 PM) *
And if you want an old fashioned look, are slightly jumpy shots, get an old Keysotone or simalar home movie camera. With its old prewar lens. If the lens is not shaded it will flare great! (I have proved this to myself in justifing the purchase of a B&H Cooke 1 Inch lens.
MAny of the camera of that era have variable speeds, none of which is actually 24 FPS, so that will also add to the look.
If you want a prop, shoot a prop and hide the Keystone inside. Heck a Devry looks like an old camera, just fake a magazine on the top, and paint the camara black/grey.
The FOMA B&W reversal can be abused to look like film that came out of a field developing kit.
Rember that most of these old camera do need double perf film.
QUOTE (Christian Blas @ Aug 27 2006, 05:19 PM) *
The other thought is that Filmos were often used a s newreel/ war cameras. they are even generaly painted alive drab. Stick a Wolensak (sp) on one and it will look good in your shot, and what you shoot will look very newsrealy. Use FOMA R-100 and the fiilm will look not too far from what you could get in 1934.
I just put a picture of some double perf stock in the atricle on Wikipedia on 16mm film, it was shot on the Foma. it sows a couple of my dogs chasing eah other...
+Quote Post
post Aug 28 2006, 03:43 AM
Post #8
QUOTE (Christian Blas @ Aug 28 2006, 12:28 AM) *
I'd imagine the single system models are pretty rare, given that they're heavy for a news camera at 24.5lb and a bit noisier than the competition. They seem to be more suitable for covering press conferences and speeches than covering a war.
+Quote Post
David Leugers
post Aug 28 2006, 08:16 AM
Post #9
Other
To use as a prop for scenes where other newsreel camermen are captured in the image, you can't go wrong with getting an Auricon or two and some B+H 70's. You can pick them up very cheap. You can see them in almost
every newsreel footage from the 1950's up into the late 1970's. To recapture some of the aura of the time period, if you can locate a good working Auricon with optical sound system, especially the pro-600 or Super-1200 models, you could use them to film with. This would give you images captured through lenses of the time (C-mount) and the sound quality to match. The look of the film footage would probably benefit from some careful selection of film stock and/or manipulation to get the look you want.
+Quote Post
Marty Hamrick
post Aug 28 2006, 10:22 AM
Post #10
If you're looking for cameras as props,you might look here :
http://www.motionpicturerentals.com/Rental/Prop.html
+Quote Post
Christian Blas
post Aug 30 2006, 10:23 PM
Post #11
Student
I have a question...If a camera runs dual pin registration (Mitchell), can it still run single perf film or it can only run dual perf?
P.S. What would happen if you run single perf film through a dual perf camera (Mitchell)?
This question bothers me the most (not the quality of film, but the camera itself).
+Quote Post
post Aug 31 2006, 01:09 AM
Post #12
You need dual perf film to run in a dual pin camera. Chances are that the second pin would tear holes into the single perf film stock and you'd end up with a film jam. The camera is fine, you just need to use the correct perf stock.
You can run dual perf stock in a single perf camera, however, you can't use dual perf stock for Super 16.
+Quote Post
Christian Blas
post Aug 31 2006, 12:36 PM
Post #13
Student
Can you modify dual perf cameras (Mitchell) or is this impossible due to some difficulties? Besides, has anyone done this before?
Is there such a thing of a single-perf Mitchell?
This post has been edited by Christian Blas: Aug 31 2006, 12:38 PM
+Quote Post
post Aug 31 2006, 01:05 PM
Post #14
QUOTE (Christian Blas @ Aug 31 2006, 09:36 PM) *
I mentioned above the Mitchell SSR 16, which had a single system sound head. this had a single claw and registration pin.
You'd have to talk to a camera engineer about the possibilities of modifying a camera. I suspect from the cost point of view it wouldn't be worthwhile because there are other single perf cameras out there.
This post has been edited by Brian Drysdale: Aug 31 2006, 01:06 PM
+Quote Post
Christian Blas
post Aug 31 2006, 04:42 PM
Post #15
Student
QUOTE (Brian Drysdale @ Aug 31 2006, 01:05 PM) *
Where might I find this camera (Mitchell SSR 16)?
+Quote Post
post Sep 1 2006, 01:22 AM
Post #16
QUOTE (Christian Blas @ Sep 1 2006, 01:42 AM) *
I suspect only in camera collections and references in "The Professional Cameraman's Handbook" and the older editions of the AC manual. I'd imagine they'd be pretty rare, the Auricon would be a much more common 16mm news camera.
You could check EBay or check out the classifieds in American Cinematographer magazine or put in a wanted ad.
However, if you want to actually shoot a film I wouldn't bother, it's only worthwhile hunting for one if you're a camera collector.
+Quote Post
Leo Anthony Vale
post Sep 1 2006, 09:50 AM
Post #17
Other
QUOTE (Brian Drysdale @ Aug 31 2006, 05:05 PM) *
If you could find one, they are noiser than contemporary cameras. Low to mid 30s Db.
Has an Arri standard mount, pre-bayonet.
The motors are pre-Xtal. A DC with sync pulse from camera and an AC sync.
Probably on the heavy side.
Having a new motor made will be pricey.
+Quote Post
Charles MacDonal...
post Sep 1 2006, 05:37 PM
Post #18
Group Icon
Other
QUOTE (Christian Blas @ Aug 31 2006, 08:42 PM) *
Kineman, (magna tech) had a mitchel 16mm on e-bay last week. They were selling it as 80% collectable 10% usable from reading between the lines on their ad. Do a ebay search for mitchel 16mm
http://cgi.ebay.com/Classic-MITCHELL-16mm-...1QQcmdZViewItem
+Quote Post
post Sep 2 2006, 01:31 AM
Post #19
That looks more like a Michell 16 Pro model.
The Mitchell SSR16 and DSR16 have a reflex viewfinder with a single lens mount and have more S35R type styling.
+Quote Post
Stephen Williams
post Sep 2 2006, 02:38 AM
Post #20
Group: Moderators
QUOTE (Charles MacDonald @ Sep 2 2006, 03:37 AM) *
I have delt with Keneman on Ebay 5 or more times. Every deal perfect. I am sure if there were any problems they would swop it for another one.
Stephen
+Quote Post
2 Pages V   1 2 >     Share this page: StumbleUpon Digg Mixx Facebook del.icio.us TwitThis MySpace LinkedIn Sphinn Kirtsy
spacer
RSS FORUM HELP         ABOUT CINEMATOGRAPHY.COM         PRIVACY POLICY         LOFI / TEXT VERSION         STEADICAM FORUM Time is now: 23rd November 2009 - 03:43 AM
