Answer Print from 16mm Reversal K40/K25?
#1 grantsmith
grantsmith
  • 138 posts
  • 2nd Assistant Camera
Posted 30 August 2006 - 04:33 PM
Is it possible if I mess up the exposure on 16mm reversal such as K40/K25 to get a print from it in the same way that you can print up or down when shooting on negative? If so is this this a simple (i.e. cheap) procedure to ask for?
Thank you.
#2 Dan Horstman
Dan Horstman
  • 94 posts
  • Washington, DC
Posted 30 August 2006 - 04:41 PM
You don't have nearly as much lattitude for Reversal films as you do with Negative. On the reversal it is pretty much what you shoot is what you get.
#3 Chris Burke
Chris Burke
  • 1720 posts
  • Boston, MA
Posted 30 August 2006 - 05:08 PM
Thank you.
It is true that with reversal film, you have much less latitude for exposure. A slight underexposer is more acceptable than an overexposure. Meter for your highlights. A good DI could probably yield fantastic results, but how much do you want to pay? The photochemical route could possibly yield satifactory results but has its own inherent risks. Try really hard to nail the exposure and you'll be lovin life.
chris
#4 grantsmith
grantsmith
  • 138 posts
Posted 31 August 2006 - 07:04 AM
thanks guys.
#5 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 31 August 2006 - 08:47 AM
Thank you.
Projection contrast reversal films generally have less latitude than color negative films. As mentioned, on reversal films, you can usually tolerate a bit of underexposure better than overexposure, as with overexposure, you lose highlight detail on the "toe" of the film's characteristic.
Most 16mm reversal is either projected directly, or a telecine transfer is made. If 16mm prints are needed, you need to make an internegative, as Kodak no longer sells a color reversal print film.
