the fire in saving private ryan
9 replies to this topic
#1 Oscar Godfrey
Oscar Godfrey
  • 72 posts
Posted 04 September 2006 - 03:15 PM
Hello.
I was wondering what creates the effect of vertical streaks seen on shots of fire in saving private ryan. I am thinking specifically of the fires at the bunkers on the beach.
#2 Matt Frank
Matt Frank
  • 78 posts
  • Pasadena, Ca
Posted 04 September 2006 - 03:24 PM
Hello.
My understanding is that this effect was created by cutting slits out of the shutter. I could be wrong though.
#3 Francesco Bonomo
Francesco Bonomo
  • 366 posts
  • currently in Rome, Italy
Posted 04 September 2006 - 03:45 PM
Hello.
If I remember correctly, I think they took the protective coating off the lenses.
#4 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 04 September 2006 - 04:01 PM
Hello.
Offsetting the shutter so as the film advances whilst the shutter is still open, causing the streaks. This has been discussed very recently. Easy to do with an Arri 435 Advanced.
Stephen
#5 David Sweetman
David Sweetman
  • 757 posts
Posted 04 September 2006 - 04:27 PM
The effect was achieved with a mistimed shutter. Usually the film is locked in place the entire time the shutter is open. With a mistimed shutter, the film begins moving while the shutter is still open. They did this at the end of the shutter's cycle, so only the highlights streak because for some reason they aren't "set" yet but the rest of the image is.
#6 Shane Bartlett
Shane Bartlett
  • 58 posts
  • Nashville
Posted 04 September 2006 - 04:49 PM
In the American Cinematographer web archives there is an article about this. A similar effect was done in Kubrick's Full Metal Jacket, which is also mentioned.
#7 isaac_klotz
isaac_klotz
  • 21 posts
Posted 04 September 2006 - 05:57 PM
well, the entire image is 'streaking' but it is the highlights which are actually noticeable. the midtones and shadows don't put out enough to make an impactful exposure on the moving negative.
-isaac klotz
#8 Alex Haspel
Alex Haspel
  • 282 posts
  • vienna, austria
Posted 05 September 2006 - 04:05 AM
-isaac klotz
That means the offset time between shutter and film transport would have to be different when trying to achieve the same amount of streaking on different fast stocks, doesn't it?
Edited by Alex Haspel, 05 September 2006 - 04:06 AM.
#9 Jon Kukla
Jon Kukla
  • 399 posts
Posted 05 September 2006 - 04:57 PM
No, it should (largely) be a function of the mechanical offset - more offset means more exposure during the pulldown. What I think is being said is that it's an effect that will only be noticeable in the highlights. Your aperture and subject will be just as important as your film stock in determining which areas will be the most greatly affected.
#10 Chris Keth
Posted 06 September 2006 - 11:50 AM
Stephen
Bingo. This is the right answer for what's going on. Cutting slits in the shutter would be like having that streak-effect, but only in dashed-line style.
There's a few shots in Zelig (shots of Woody sitting outside of the country cottage at a table) where the same thing happened.
Edited by Christopher D. Keth, 06 September 2006 - 11:52 AM.
