Carrying over camera sheets
#1 grantsmith
grantsmith
  • 138 posts
  • 2nd Assistant Camera
Posted 05 September 2006 - 05:30 AM
At the end of the day I always shortend what is left on the mag and sign off the sheets everyday.
I was recently working on a low budget shoot where they were not going to send off the rushes until the end of the shoot.
The DP asked me to not bother short-ending and to 'just continue tomorrow' with the mags.
What is the correct procedure to do this? i.e. with the date on the sheets, date on the board etc?
Should I just write 'continued from previous date' on the information section?
THanks
#2 Mike Panczenko
Mike Panczenko
  • 324 posts
  • Philadelphia, USA
Posted 05 September 2006 - 11:47 AM
When you leave a mag to be used later, you write on the report "IP" or "In Progress" at the place you left off and change the strip of tape on the case where you store the mag to say "IP @ 250" (or wherever you left off). Put labels on the mag too (IP @ xxx), as if you were putting up a short end, because, essentially, when you start the next day, you are starting with a short end. For inventory purposes, I would change the date on the camera report and mag label to the day that you finish shooting the roll, because it doesn't enter your inventory sheet until you finish shooting it. The date on the slate should be the actual date. No need to make the date on the slate match up.
#3 Jon Kukla
Jon Kukla
  • 399 posts
Posted 05 September 2006 - 05:06 PM
For camera sheets, if nothing's going in until the end, then I'd advise just continuing the sheets as if it were a one-day shoot. Keep it simple and compact, especially as nothing is getting separated through different days and baths.
#4 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 07 September 2006 - 06:41 AM
The only time I would leave a hot mag was when it was a scene that we were to continue shooting the next day. If you finish a scene then it makes sense to send everything off to the lab, since the editor will want to get all the footage at the same time.
#5 Phil Rhodes
  • 12171 posts
Posted 07 September 2006 - 02:14 PM
This becomes an issue when shooting data, since you don't want to offload a mag when it's half full. I've seen elaborate paperwork systems in place to deal with this, which I think rather defeats the object.
Phil
