RED website update
17 replies to this topic
#1 Emanuel A Guedes
Emanuel A Guedes
  • 528 posts
Posted 08 September 2006 - 06:08 AM
RED 18-85mm PL mount zoom
http://red.com/lenses.htm
RED workflow
http://red.com/workflow.htm
RED design
http://red.com/cages.htm
#2 Emanuel A Guedes
Emanuel A Guedes
  • 528 posts
Posted 08 September 2006 - 01:23 PM
$10,000 price range
RED workflow
REDCODE = 216 megabits/second@24fps
RED design
RED DRIVE 80GB@$1,000
Edited by Mr. Emanuel A. Guedes, 08 September 2006 - 01:24 PM.
#3 Mark Allen
Mark Allen
  • 591 posts
Posted 08 September 2006 - 01:52 PM
$10,000 price range
I'm going to reiterate some of that:
REDCODE (10 bit wavelet) = 27 MB/seccond @ 24 fps
UNCOMPRESSED (12 bit raw) = 323 MB/s @ 24fps
FireWire 800/400, USB-2 and e-SATA interfaces
RED-DRIVE™ hard disk drive (40 – 160GB)
REDFLASH™ flash memory (32 – 128GB)
Where did you get the price quotes on the lense and drive?
Is 10k a lot for a lense? Seems like a good cine quality zoom would be in that range, no?
As for the 1k for 80 gig - if that means 160 gig for 2k... that's pretty cool. That's a ton better than the HVX storage solutions.
So - using the red-drive and red flash you would get:
REDdrive
raw:
2 minutes to 8.25 minutes
wavelet:
24 minutes to 98.76 minutes
The RED flash would be about 3/4 of this
The thing I've not visually grasped yet is how that shoulder mount works at the same time as the cage - just keeps seeming like the cage would hit your head. Would be curious to see that in use so I understand it. Not that I do much or any shouldermount stuff, but it would be interesting to see.
And just to appease the masses. Yes... the camera is not built yet. It is purely an inention, a goal, a hope. It's a work in progress and everyone including the RED team themselves will not only acknowledge this but tell you flat out that it's a really difficult thing to do.
Can someone explain what this means from an aesthetic point of view?
Dynamic Range:
> 66dB
#4 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 08 September 2006 - 02:10 PM
Although I presume that a lot of prosumers are going to be shocked by the price, 10K is quite cheap for a brandnew a zoom lens. Although I don't have the exact price, I would presume that the 17-80mm Optimo is at least 4-5 times as much. But with the Optimo you're getting a top notch zoom lens which is nearly as fast as a prime (T2.2).
I'd be interested in more details about this Red zoom lens. Weight and minimum focus for one. Also whether it is purpose build or just rehoused stills glass and how bad the breathing is (which isn't really an issue with the Optimo for instance).
#5 Emanuel A Guedes
Emanuel A Guedes
  • 528 posts
Where did you get the price quotes on the lense?
http://www.studiodai.../news/7075.html
and drive?
http://red.com/faqs.htm
#6 Thomas James
Thomas James
  • 844 posts
Posted 08 September 2006 - 02:18 PM
I thought the camera was supposed to shoot 4k at 60 frames per second rather than 24. Thats the whole point of going digital so we can increase temporal resolution which will be good for action movies. But nevertheless if the camera can shoot 2k at 60 frames per second that will still be a good thing.
#7 Mark Allen
Mark Allen
  • 591 posts
Posted 08 September 2006 - 02:21 PM
According to this chart you can:
http://red.com/formatoptions.htm
near the top left corner.
#8 David Sweetman
David Sweetman
  • 757 posts
Posted 08 September 2006 - 02:23 PM
I think it's "maximum 60 fps."
#9 Emanuel A Guedes
Emanuel A Guedes
  • 528 posts
Posted 08 September 2006 - 03:12 PM
Still about the zoom lens price:
http://www.dvinfo.ne...ead.php?t=75097
#10 Phil Rhodes
  • 12171 posts
Posted 08 September 2006 - 05:25 PM
Woah, that'd better be some very, very special hard disk.
Or is it, as I suspect, a completely bog-normal hard disk in a special case marked "RED" and priced accordingly?
Get real.
Also - this "red rail" thing had better just be normal mattebox rods. Anything else, not being compatible with x^y other accessories out there, would be grotesquely stupid.
Quite like the cage idea.
Phil
#11 Emanuel A Guedes
Emanuel A Guedes
  • 528 posts
Posted 08 September 2006 - 05:36 PM
It's fair your doubt but I ask myself if is it fair to think that a laptop spinning drive may handle 27MB/s?
#12 Phil Rhodes
  • 12171 posts
Posted 08 September 2006 - 05:38 PM
Probably not, but a 3.5" full size drive would, especially in an embedded situation.
Phil
#13 Simon Wyndham
Simon Wyndham
  • 146 posts
  • UK
Posted 08 September 2006 - 05:56 PM
A better strategy for Red would have been to reveal the projects existence at IBC along with the footage. A lot of rubbish could have been prevented that way.
Hopefully Jim still reads these forums. If so I just want ask a very simple question that will satisfy the issue I currently have seeing as I can't get any sense over at the other place.
Is the rail mount that is currently on the Red website the general purpose shoulder mount that has been mentioned in the past, or is another one also in development? I know you've said that things will change, and thats great. But will Red offer a general purpose cage/shoulder mount that will offer pefect balance and have the ability to be tripod mounted and demounted quickly?
Has anything firm been decided as far as viewfinder options go?
#14 Emanuel A Guedes
Emanuel A Guedes
  • 528 posts
Posted 08 September 2006 - 10:38 PM
Hi Simon!
I'm frankly glad to see you here my friend. For sure, Jim reads any of your good comments. I hope to watch good things shot with the RED cam from your eyes, as well.
Cheers!
Emanuel
#15 Brent J. Craig
Brent J. Craig
  • 64 posts
  • Toronto
Posted 09 September 2006 - 11:22 AM
I just don't understand the pricing for all these "HD" hard drives coming out.
I can buy a 500 GB 3Gb/second SATA II drive for $278 here in Toronto. If a single drive wasn't fast enough to keep up with that data stream, you could string 3 together in a RAID configuration and have one and a half terabytes of storage for $834 in drive costs.
I'm sure all the firestores and red drives of the world have some fancy electronics, but $$1000 for 80 gigs? You can't even buy 80 Gig drives where I shop for PC parts, they are so obsolete.
Can someone shed some light on why they are giving us thimble-fuls of storage when we need buckets (or barrels)?!?
#16 David Mullen ASC
Posted 09 September 2006 - 11:28 AM
It's not just memory you are paying for, but processing speed and other things necessary to handle all of that real-time data. You can't just hook a camera to an ordinary hard drive without intermediary software and hardware to manage the data.
#17 Phil Rhodes
  • 12171 posts
Posted 09 September 2006 - 12:43 PM
The point is that all that intermediary software and hardware should be part of the camera, or a semipermanently-attached add on to the camera. The actual interchangeable storage media should be as minimal as possible, and given that we're hearing about a data rate that's just about achievable for a single 2.5" disk, that's what I based the comment on. Even given that there might still be an interface board involved, 80Gbyte for $1000 is insanity for a normal hard disk.
I suspect what they might be doing is making each mag a three-disk RAID-5 of smallish, circa-20Gb NAS drives. This would provide very good performance. Unfortunately there's almost any number of options here which could justify or not any price point they cared to name.
Phil
#18 Graeme Nattress
Graeme Nattress
  • 145 posts
Posted 16 September 2006 - 08:24 AM
I'm sure we said the price of the drive was < $1000, the "<" being the key part.
Graeme
