Changing setup on SOny 750
#1 grantsmith
grantsmith
  • 138 posts
  • 2nd Assistant Camera
Posted 11 September 2006 - 05:24 AM
Hi THere,
I don't have one in front of me but can anyone tell me the procedure for changing the set-up on th 750.
It is either to use one of the pre-sets or use a card (not sure yet)
I've only done it once before and can't remember how to do it. I'm sure it was on page 50 and was fairly straight forward but would like to be safe.
#2 Brian Drysdale
  • 5193 posts
Posted 11 September 2006 - 05:55 AM
On the HDW 750 you can either have your set up on a Memory Stick or in the camera's User Menu.
However, if it's a rented camera that it mightn't be set up the way you want, so you'll need to check through the menus to see how the camera is set up and making adjustments as required. You can then store these new settings in the camera and write them onto a Memory Stick (if required).
#3 grantsmith
grantsmith
  • 138 posts
Posted 11 September 2006 - 06:03 AM
thanks brian,
yep, its a rented camera. its the procedure for changing the settings I'm looking for. I'm not sure if the dop has his own card. The rental company usually have a selection of 'common' set-ups, so it may be one of those he will use. I'd like to be able to quickly be able to do both without asking him. its too lote to phone the rental house.
I've done it plenty times on the 790 but i'm not so familiar with the 750.
