netting lenses?
10 replies to this topic
#1 Chris_Burket
Chris_Burket
  • 77 posts
Posted 27 September 2006 - 02:02 AM
I have heard this term quite frequently. "net the rears of the lenses"... What's it mean, how do you do it? What effect does it produce?
#2 Daniel Madsen
Daniel Madsen
  • 201 posts
  • Boston
Posted 27 September 2006 - 04:27 AM
This topic was discussed extensively in reference to Janusz Kaminski. Try a search.
#3 Chayse Irvin
Chayse Irvin
  • 409 posts
Posted 27 September 2006 - 04:42 AM
Having trouble finding results. Can you hook us up with a link?
#4 Adam Frisch FSF
Adam Frisch FSF
  • 2027 posts
  • Los Angeles, USA
Posted 27 September 2006 - 06:25 AM
Basically you attach a nylon stocking to the back of the lens. Some do it with nail varnish, but I prefer Blue Tac (or White Tac). You are free to use any stocking you like, but the low grade, thick ones you buy in regular supermarkets simply won't cut it. Most people go for really thin ones (black, not brown), and thin menas expensive, unfortunately. On the other hand, a $100 pair will last you a lifetime.
The favourite brand used to be Christian Dior's thinnest, but I think they've ceased making them. That leaves Fogal as the preferred brand. I've uswed Fogal a couple of times and it works fine - it's quite subtle on 35mm, but rather pronounced on 16mm. Also depends on how you stretch it across the lens.
You get multi-coloured halations around the hightlights/flares, so depending on if you like that or not, that's something to look out for. The film From Hell has a lot of behind-the-lens nylon work in it, especially in the flashback sequences and often combined with the cross-processed footage. Nicely shot movie by Peter Deming, ASC - well worth having a look at just for the look.
#5 darrin p nim
darrin p nim
  • 95 posts
  • Los Angeles, Ca from Portland, Or
Posted 27 September 2006 - 06:41 AM
any visual examples, im curious about this look.
#6 Bob Hayes
Bob Hayes
  • 1087 posts
  • Culver City, California
Posted 27 September 2006 - 10:40 AM
Fogal works great. I built little rings that slide over the back element allowing me to remove and replace the nets quickly. As an AC gluing nets on made me nuts. Really time consuming. Especially on a commercial when the DP would show up that morning with the nets.
#7 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 27 September 2006 - 11:35 AM
What Fogal's? They make at least 100 different styles of stockings.
#8 Wendell_Greene
Wendell_Greene
  • 545 posts
Posted 27 September 2006 - 12:03 PM
Sure. The link below leads to a topic discussion Kaminski's use of diffusion, as well as other DPs like Robert Richardson, ASC. It has photo examples, courtesy of David Mullen, ASC. Enjoy.
Topic 1 with photo examples
Dior or Fogal stockings, usually in black seem to be popular among cinematographers partial to using stockings/nets behind the lens. Testing, as always, is recommended.
#9 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 27 September 2006 - 01:38 PM
Fogal Noblesse Number 10 and classic soft (or 11, cant remember):
If you call the Fogal store in NY and tell them what you are doing, they will tell you which style all the camera people are buying. Should be around $75 to $90 a pair, get extra large ;)
Kevin Zanit
#10 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 27 September 2006 - 02:11 PM
Kevin Zanit
For my "full fiqure" lenses?
Great suggestion, call Fogal in NYC. Thanks Kevin!
#11 Brian Drysdale
  • 5197 posts
Posted 27 September 2006 - 04:06 PM
I've just ordered a leg from South London Filter.
