Help!
#1 Glenn Brady
Glenn Brady
  • 328 posts
Posted 28 September 2006 - 08:35 AM
Can anyone tell me the accessory thread size on the Kern-Paillard 5.5mm f/1.6 H8 RX Switar lens? I need a step up ring from this accessory thread to 52mm. The accessory thread is larger than 30M.
#2 boy yniguez
boy yniguez
  • 92 posts
Posted 29 September 2006 - 02:11 AM
i believe that would be for the Bolex RX camera so the standard name for the mount would be C-mount.
#3 Glenn Brady
Glenn Brady
  • 328 posts
Posted 29 September 2006 - 05:54 PM
Yes, the lens is a C-mount, but I need the dimensions of the accessory thread - that's the thread on the front of the lens, not the rear. I want to experiment with some wide angle conversion lenses, but I've been unable to find an adapter to fit the front of the lens.
#4 Glenn Brady
Glenn Brady
  • 328 posts
Posted 09 October 2006 - 10:33 AM
The factory tells me the thread diameter is 32mm. Presumably, the pitch is 0.5mm or 0.75mm. Does anyone have a clue where I might get an off-the-shelf 32mm to 52mm step-up ring?
#5 Mike Rizos
Mike Rizos
  • 330 posts
Posted 09 October 2006 - 06:52 PM
That's a very strange size thread. You may have to attach the ring to the Switar by your own method. You may also need two rings to get to 52mm. Try this place in the UK.
http://www.vintageca...uk/stepping.htm
