net behind the lens
7 replies to this topic
#1 Ram Shani
Ram Shani
  • 735 posts
  • isreal
Posted 02 October 2006 - 03:08 PM
hi
i started to experiment with behind the lens nets in video shooting
and want to know if any of you recommend on net's to use
i want to build a kit for video shooting
need any tip
#2 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 02 October 2006 - 03:16 PM
http://www.cinematog...n...t=Search&f=
#3 Ram Shani
Ram Shani
  • 735 posts
  • isreal
Posted 02 October 2006 - 03:22 PM
thank Kevin but i looking for net's to use on video only and didn't find it on the search
#4 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 02 October 2006 - 05:35 PM
Well, they are used more or less the same way. The effect of the net tends to be more apparent with 2/3 cameras because of the deeper depth of field, so you may need to stretch them a little tighter.
I just use snot tape around the edge of the rear. If it's a zoom, be careful to see if the rear element moves a lot and how that would affect what you put on it.
#5 Brian Drysdale
  • 5198 posts
Posted 03 October 2006 - 04:24 AM
I Rings are a neat and quick way of mounting nets on the back of video lenses.
#6 Ram Shani
Ram Shani
  • 735 posts
  • isreal
Posted 03 October 2006 - 05:06 AM
names i need names of nets
#7 Brian Drysdale
  • 5198 posts
Posted 03 October 2006 - 05:30 AM
Some are discussed here:
http://www.cinematog...showtopic=17450
#8 Rupe Whiteman
Rupe Whiteman
  • 336 posts
Posted 04 October 2006 - 10:26 AM
I use black bridal gown netting mounted on an i-ring for the rear element. It's a nice flattering type of diffusion and is good for softening the harder egdes video can create. You just have to watch out for direct lighting sources down the barrel of the lens as then you can see the reftracted shape of the netting... nb bridal gown also comes in white...
Rupe Whiteman
