screening: Digi-Beta vs. HDV
13 replies to this topic
#1 Charles Haine
Charles Haine
  • 127 posts
  • Colorist
Posted 10 October 2006 - 02:53 PM
So, I was let into a festival with the promise that they screened "everything, D5, HDCAM, whatever you've got." I shot my short 35mm, and mastered it to HDCAM and D5.
Now they are telling me they only screen HDV.
My question: Should I output my HD version from Final Cut to an HDV camera, and project that, or should I show my Digi-Beta? I'm personally leaning towards showing the digi-beta, for the color space, but I would appreciate any feedback you have.
thanks,
Charles Haine
#2 Chris Burke
Chris Burke
  • 1726 posts
  • Boston, MA
Posted 10 October 2006 - 03:32 PM
thanks,
Charles Haine
I am going through a similar experience where I shot on Super 16 and have a HD master as well as Digi-Beta screeners. Many projectionist that I have spoken with say, when in doubt, go with Digi-Beta. It is a tried and true format, HDV is a consumer format that is very young. Which festival did you get into?
Chris
#3 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 10 October 2006 - 04:26 PM
thanks,
Charles Haine
Is it an action film? The reason why I ask is HDV compression has a problem with movement but looks stunning if the camera is fairly still.
Stephen
#4 Thanasis Diamantopoulos
  • 99 posts
  • greece
Posted 10 October 2006 - 05:02 PM
thanks,
Charles Haine
Hi
I dont realy understand if they are only screening hdv do they acceptet digibeta?
BTW even if i like digibetas colors vs hdvs you must thing that the screening system in the festival
must be "calibrated" to hdv, sking for it.
#5 Sam Wells
Sam Wells
  • 1751 posts
Posted 11 October 2006 - 09:55 AM
Hi, just saw a piece in the New York Film Festival, 16mm > HDCam transfer, projected with HD projector (I don't know which) from HDV tape, looked fantastic.
-Sam
#6 David Cox
David Cox
  • 323 posts
  • Digital Image Technician
  • london, UK
Posted 12 October 2006 - 05:59 PM
I'm not in the least bit a fan of HDV BUT....
HDV compression is an enemy to post production, not necessarily to "final delivery". Compressed final delivery is normally fine, because the compression used is designed to be as invisible to the human eye as possible. On the other hand, HDV shot material lacks a lot of the data that our computer based post systems want to get their teeth into for grading, keying, tracking etc.
So I would say (and agreeing with Stephen re fast motion) that projecting from HDV should be fine within reason, but you wouldn't want to use it as a mastering format during post production or where your "master" tape might be used for future editing or effects work.
David Cox
Baraka Post Production
www.baraka.co.uk
#7 Sam Wells
Sam Wells
  • 1751 posts
Posted 12 October 2006 - 07:37 PM
So I would say (and agreeing with Stephen re fast motion) that projecting from HDV should be fine within reason, but you wouldn't want to use it as a mastering format during post production or where your "master" tape might be used for future editing or effects work.www.baraka.co.uk
Of course not (I hope I didn't imply as much) but that wasn't the question.
-Sam
#8 Charles Haine
Charles Haine
  • 127 posts
  • Colorist
Posted 13 October 2006 - 12:28 AM
thanks a lot for all that really helpful info: my suspicion was that the compression drawbacks of HDV were worse as a capture format, but it might be worth it to screen on it (when compared to Digi-Beta, the extra resolution would be worth it), and you guys seem to agree. Very thorough and intelligent answers.
Since we mastered to D5, hopefully the downconvert will look good.
Regarding a bit of confusion: I meant to say the only HD format they can show is HDV; they can show all sorts of SD formats.
thanks again,
chuck
#9 Sam Wells
Sam Wells
  • 1751 posts
Posted 13 October 2006 - 10:39 AM
I would be inclined to chance it with the HDV - hope I'm not steering you wrong --- really I'd be more concerned with the projector. Is it really an HD machine ?
(I'm still trying to find out what projector the Walter Reade was using)
-Sam
#10 Keith Mottram
Keith Mottram
  • 824 posts
Posted 13 October 2006 - 11:03 AM
I am confused as to how they are projecting an hdv source, as i have never come across an hdv deck with hd sdi out and i don't know of any projectors that take hdv via firewire or hdmi?? could it be that they have a sony hdv deck which can output an sdi sd downconvert? in which case i would go with digibeta.
keith
#11 Michael Most
Michael Most
  • 765 posts
Posted 13 October 2006 - 12:12 PM
I believe the Sony units (at least one of them) have component out. Most projectors can take analog component inputs.
#12 David Cox
David Cox
  • 323 posts
  • london, UK
Posted 13 October 2006 - 08:35 PM
...yes, or through a firewire to HD SDI converter such as a Miranda converter.
David Cox
www.baraka.co.uk
#13 Sam Wells
Sam Wells
  • 1751 posts
Posted 18 October 2006 - 10:24 AM
-Sam
Found out: Christie Roadster S6. 3 chip DLP with "Dark Chips"
-Sam
#14 Keith Mottram
Keith Mottram
  • 824 posts
Posted 20 October 2006 - 08:22 AM
I could be wrong but I thought that the component out was only sd. can anyone confirm?
