trouble with quicktime
#1 David Calson
David Calson
  • 269 posts
  • Georgia
Posted 12 October 2006 - 11:48 PM
Hi, so I exported these video files as quicktime movs. They play smooth on my comp. I then burn them to DVD. They play for a few seconds than stutter to a stop then stutter/skip through the timeline. I play it on different comps with the same results. I re-burn with different discs and get the same results. I play past quicktime discs that I have made and it runs smoothly. I open the corrupted movs on different players and get the same crappy results. I use premiere pro 1.5 with sorenson 3 compression. This workflow has never let me down and even the finished exported files look great...until I put them on a disc. Any ideas? Thanks.
#2 Keith Mottram
Keith Mottram
  • 824 posts
Posted 13 October 2006 - 07:52 AM
i assume from this that you are burning the qt onto the dvd as data rather that a dvd encode. in which case the simple fact is that the computers cant 'stream' the qt's quickly enough for playback. either make data dvds with qt of a very low bitrate or burn encoded dvds for viewing.
keith
#3 Bernhard Zitz
Bernhard Zitz
  • 342 posts
  • Z├╝rich, Switzerland
Posted 13 October 2006 - 09:26 AM
If you don't play it off harddisk I'd make proper Video-DVD's that play on any DVD-Player...
#4 David Calson
David Calson
  • 269 posts
  • Georgia
Posted 13 October 2006 - 10:29 AM
very good answers thanks guys. So my dvd rom isn't fast enought to stream? So that means its just a problem with the computer not anything defective with the actual disc?
#5 Marek Stricek
Marek Stricek
  • 23 posts
Posted 13 October 2006 - 11:18 AM
you can check if the mov files on the DVD are OK by simply copying them from DVD back to the harddrive and then play them from harddrive - if the copying procedure went smoothly and the files play OK from harddrive then the DVD ROM is not fast enough
